Auto Volume Adjust
Old 08-20-2016, 01:18 PM
Glacier6's Avatar
Default Auto Volume Adjust
Not sure if this is just B&O only or if it happens with the Bose system as well, but the volume will actually fluctuate on its own depending on speed, a/c fan setting, etc.
Does anyone know how to deactivate this?
Old 08-20-2016, 05:43 PM
Lookout57's Avatar
In Sound Settings, Audio Pilot (I think is the name)
Old 08-20-2016, 07:23 PM
snagitseven's Avatar
It's purpose is to adjust the volume based on interior noise relative to your volume setting. I'm pretty sure the C7s don't have a way to turn this off in the settings. I do seem to remember where the amount of volume compensation can be adjusted with Vag-Com. That might also turn it off. Perhaps someone can chime in if they have found a way to do a mod.
Old 08-21-2016, 03:04 AM
jjsC6's Avatar
On a related note, after backing up and the system mutes itself it does not always come back on when I put it in drive. Sometimes it does, sometimes not. It's a crap shoot. Anyone else?
Old 08-21-2016, 07:34 AM
Peter B.'s Avatar
Yes, I have the same problem with my S7.
Old 08-21-2016, 08:01 AM
Glacier6's Avatar
Yes, which is exactly why it makes no sense. There's a reason for a volume setting and that's so it stays at the level I set it at no matter what the circumstances. If I want it louder or softer I'm pretty sure I'm capable adjusting on my own and when I want.
And it seems like a vag-com really can solve most issues....
Old 08-21-2016, 10:27 AM
chucky0731's Avatar
In the Sound Setting, adjust "Dynamic Sound" to minimum to turn off this feature.
Old 08-21-2016, 04:52 PM
I forgot about this setting. In my A6, with the Bose system it's called "AudioPilot" and with the B&O it's called "Volume Balancing". With the Bose it can only be turned on or off; with the B&O the amount of noise compensation is variable from off to max. These should be located in the sound settings menu.
Old 08-22-2016, 06:44 AM
Glacier6's Avatar
Awesome thank you!!
Old 08-22-2016, 10:01 AM
Maui19's Avatar
Me too. My radio will turn itself on about 75% of the time when I shift from reverse to drive. It is very flaky.
killahb36
A4 (B7 Platform) Discussion
01-16-2007 01:46 PM
Timmay
22
03-04-2006 05:40 PM
ayethree
Audi A3 / S3 / RS 3
11
01-13-2006 06:38 PM
chuckdawg82
04-11-2005 12:48 PM
The Mystro S4
03-23-2001 09:27 AM
Quick Reply: Auto Volume Adjust
