Center Speaker Replacement
Has anyone found a drop in replacement for the center speaker in an A7 dash?
The folks over on the A6 board have solved the common buzzing problem with the Bose unit using a Kenwood KFC-1065S. However based on my experience it seems that, although the A6 and A7 use the same Bose part, the available mounting depth is about 1/2" less in the A7.
Any insight much appreciated.
New owner here: I've been battling the same issue in mine. I was getting alot of grill rattle, and have fixed that by adding lots of felt tape on contact surfaces between the grille and the dash, as well as carefully adding a slight bit of hot glue on parts where the grill piece was rattling against itself.
Now that the rattle is gone, I can finally hear the speaker distorting :/
I haven't pulled the speaker to look at it, though when I worked in the car audio industry years ago, Bose used 8 ohm speakers, so I would be hesitant to put a 4 ohm speaker in its place.
I have had good luck ordering individual speakers from some online audio suppliers (PM me if you want more info, I don't know all the rules here, and don't want to sound like I'm advertising for anyone).
I should be able to get my speaker pulled this weekend, I'll update with what I decide to do if anyone is interested.
Removed
I ended up pulling the speaker completely while I search for a replacement. I'm not sure if it's purely psychological, but the system sounds infinitely better without the speaker rattle.
Bose system on A6/A7 has 4" midrange all over in 4 doors and center channels. They could be very few drop-in because most of them after market speakers are designed with 4 drilling holes. They should come with a 2 to 4 holes adaptor.
Yet the depth is most likely not going to be an issue.
Rattling could be another story. You tried the dynamite before?
