Brake Pads noise problem
I have recently changed the front rotors with the brake pads . I got the rotors from the stealer and the pads are Textar (4 pad each side with the spring model ) the first two days everything was ok and the third day the juddering began this is not the first time I get this when changing the pads ( eventually the noise goes away by time) but I have been told it was from the rotors last time so I changed them and the problem was not solved .When the pads and rotors are cold in the morning everything is quiet and calm after 10 15 minutes of driving the orchestra began to play . should I check the calipers ? what should I do ?
If the juddering is happening when braking it might be the lower arms are on the way out and need replacing had the problem on mine, also did you service the calipers? because they are metal and rust easily so the pads might be stuck on the disc.
Thank you for your reply the juddering is coming when doing from stand still to 25-30 mph then it will go away on the highways without braking( the juddering on braking is from the brake pads ) my problem is when accelerating from 0 to 30 mph .the problem is when they are cold everything is normal . how can I service the calipers ?is there any specific way to do them ?
HONER
RS4 (B7 Platform) Discussion
23
11-01-2007 04:07 AM
CO AVANT
06-05-2005 12:20 PM
boost-addict
05-17-2001 10:27 AM
StephenW
01-04-2000 05:46 PM
