Durable engine? 2.5 3.3 or 4.2?
Hello, I am currently looking for an Audi A8 D2, because I really love this car. Now I know these cars are getting old and I have to keep a lot of things in mind before I buy one. Most of the cars have a milage of around 250k to 300k Km. I want to buy the one that I can still can use for at least 2 years.
What displacement should I look for? The 2.5L would be nice because it uses the least petrol, and the 3.3L and the 4.2 are beasts, but what engine is the best, looking at durability and maintenance?
Kind regards,
Michel Prins
Kind regards,
Michel Prins
I can only speak to the 4.2, but from what I've read these engines are good for 250,000 - 300,000 miles.
I have 118,XXX on my 4.2 and the only thing, engine related, is a slight oil leak from the lower oil pan seal. Not a big issue because the amount is so small, it doesn't affect the oil level.
One thing I'm keeping an eye on is the oil cooler pipe, a known issue for 4.2 engines, but the 2.5 and 3.3 might have the same oil cooler pipe issues, as well.
Like most anything that is used, find one that has been taken care of by the previous owner(s) and you should be good.
Good luck.
Good luck.
Good luck.
Good luck.
But, in this case, forged may be no advantage, especially for longevity. The metallurgy, casting and cold cracking process makes a more stable and much more precise fit between top and bottom halves of the rod, translating into longer bearing life. ...and plenty strong enough for the stock or moderately "modded" engine.
Cheers
The piston rods ... FL A8 has cast cold cracked rods. I believe PFL 4.2s had forged rods also.
Cheers
Cheers
So you would recommend the 3.3L ? Instead of 4.2?
4.2, no question.
The 2.5 and 3.3 are both diesels. The 2.5 is a V6 and is possibly the worst Audi engine of all time. Only 180hp, yet it weighs the same as the 4.2. The camshafts wear out, then the rockers fall out, then the hydraulic lifters pop out, and then while it's munching up the pieces it loses oil pressure and destroys itself. The engine is more popular in Poland than in the UK, so replacements are easier to get, but do you really want to consider the engine a consumable? No. Run far, far away!
The 3.3 is a V8, and is unique to the D2 and therefore extremely rare and extremely complicated. While it might be an interesting curiosity, and would probably make a ton of torque when tuned, it would be very expensive if anything went wrong.
The 2.8 V6 is underpowered and noisy, and has to be thrashed so hard to get the car to move that it uses more fuel than the V8s. It is bearable with FWD, but who wants an FWD A8? It is probably the cheapest engine to maintain since it was fitted to A4, A6 and Passat so bits a common and cheap, and its fairly easy to fix. Its also pretty much bulletproof. Just boring.
While the 3.7 V8 gets down the road just fine by European standards (with 260hp) and can even achieve 30mpg when treated nicely, you're constantly left wondering how much more fun the 4.2 would have been!
4.2, no question.
