Major leak
Major leak
Having problems with water in the car its going from some where behind the glove box, has any one had this problem and knows how to deal with it?
Thanks
Thanks
Here >>
audipages Unclogging the A8 Evaporator Drains
Yes -
Yes, you need to clean out your rain drains under the hood ...AND you need to clear the interior AC drains in the cabin. Even if not using the AC, overflowing rain water will drain out the interior AC drains if they are clear.
Here >>
Here >>
2 ways the water gets in up front:
1) fills the area under the hood up by the firewall/cowl area. 4 drains there 2 center and 1 over each wheel well. IF it fills too high, it can get in through the cabin air inlet (center of cowl) and through any little holes into the cabin. It can also fry your ECU/TCU in the underhood electronics box.
2) Your breath. water vapor condenses on the AC coil...turns to droplets on the tray under the dash...but the drains on this condensate tray are clogged...so it fills up and splashes out when you turn...It's people water...yuck
SilverToronto
07-23-2002 06:58 AM
