Power steering pump?
So, recently my pump have been a struggle and a pain in the a**!
But it seems to be 2 different pumps for this car?
Picture #1 is the replacement pump from ebay everyone seems to be selling!
And pic #2 is the one that looks like mine! please help! Can i change to the #1 pump or do i have to get the old one cause i cant find it anywhere!
pic #1 http://assets.suredone.com/1517/medi...6-a8-s8-d2.jpg
Pic #2 http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/a1QAAOxyaURTf1dX/$_35.JPG
That 2nd one looks like a 30v V6 pump.
The V8 pumps are all like the 1st one.
I have a 30V one I'll sell you if you're in Australia!
Part numbers are everything, though.
If this is the '95 D2 mentioned in an earlier thread, does it have self leveling rear suspension? ...Have you looked at the part number compared to the one for sale? ...extra set of out/inlets on the pump?
D2 Tandem vane pump 4D0 145 165 N >>
It Is an 4,2 ABZ with hydraulic leveling system, which isn't used anymore because it started leaking. Non US btw! So what you are saying is that I can use the first pump if I don't use the leveling system?
This pump should fit my car wouldn't it? http://www.ebay.com/itm/B-Ware-Hydraulikpumpe-Servopumpe-Audi-A8-D2-4d-/301490633349?pt=DE_Autoteile&fits=Make%3AAudi%7CModel%3AA8&hash=item46323dfa85
This pump should fit my car wouldn't it? B Ware Hydraulikpumpe Servopumpe Audi A8 D2 4D | eBay
It's the correct part # for a non-self-level D2.
iv put a uv dye in my ps fluid and it leaks in the middle of the pump,i guess it is consisted of 2 pieces and 4 bolts secure that there is no leak.
Is there a gasket in the middle of the pump that can be changed or i should try tighten the bolts?
have you ever seen p/s fluid leaking in where the steering shaft goes through the firewall? When I remove the floor mat there is some sort of oil dripping down from where the shaft goes through the firewall. It had to top off the p/s once a couple years ago, so it must be a pretty slow leak but enough that you can see it puddle and then run down the insulation mat. I'm guessing the end of steering rack is right at the firewall? Can't think of anything else there that would leak.
Witt_4rings
11-14-2014 04:42 PM
~DonQPremiumTequila~
08-13-2008 01:21 PM
OneEighth
04-24-2002 06:00 AM
evan
11-03-2000 10:12 PM
