Sponsored by:
Sponsored by:
1998 A8 D2 Boot problems
Old 12-14-2010, 01:27 PM
jonah290's Avatar
Default 1998 A8 D2 Boot problems
Another conundrum for everyone,
This is how it goes, the central locking boot pump doesn't lock/unlock, I have to use the key in the boot lock (Old skool huh). I can here it hissing and humming, it seems to over run for nearly 60 secs. The boot also shuts oddly, as you look at the back of the car, the one side of the boot looks open while the other looks really shut!!
Help please
Mark
Old 12-14-2010, 02:55 PM
silverd2's Avatar
It almost sounds like you have a hinge problem...maybe one bent inward (or outward)or binding somehow...or a binding strut. Not much else would cause the boot lid to settle that unevenly....other than the rubber lid stops on each side. A hinge not folding or strut not compressing correctly could prevent the lid from popping up under it's own power.
Old 12-15-2010, 05:08 AM
jonah290's Avatar
Sam,
The uneven closing was down to a small bolt rolling round in the back of my trunk, it must have come out with something else and dropped off back to then obstruct the boot lid. It was very dark when I was looking and didn't spot it until today. I still have to sort the problem with central locking controlled trunk lock. I'll live with it until I have some spare time over the festive season. It'll be a pump or rod or pipe or something.
Cheers
Mark
Old 12-15-2010, 05:10 AM
jonah290's Avatar
The bolt causing the obstruction, by the way was not off the car!!! It was just relating to my job.
Old 12-15-2010, 09:40 AM
tozoM8's Avatar
You have a leak in the system. If you vag-com it, it will have a fault code for pump overrun. One of the diaphragm or the flexible hose is torn.
Old 12-20-2010, 12:32 PM
jonah290's Avatar
Thanks Tozo,
I'll strip the tailgate lining of when I get a couple of hours.
Regards
Mark
Jack Grindlay
Audi A3 / S3 / RS 3
05-10-2018 09:12 AM
grahamjf
A4 (B7 Platform) Discussion
10-13-2016 11:30 PM
Zaytar
16
01-26-2015 07:58 AM
Mass1968
03-02-2014 12:47 AM
Goughy
Audi A3 / S3 / RS 3
11-03-2004 03:25 AM
Quick Reply: 1998 A8 D2 Boot problems
