Sponsored by:
Sponsored by:
ABS Light came on this morning. Time to clean the sensors I guess.
Old 11-29-2004, 09:02 AM
Mitaka's Avatar
Default ABS Light came on this morning. Time to clean the sensors I guess.
I was backing up from my garage and the ABS light came on together with a blinking red <BRAKE> light. Stoped the car and after restart it was all OK. Then later in the day the same thing. Do you think cleaning the sensors will fix the problem?
Old 11-29-2004, 10:58 AM
ex-a8drifter's Avatar
I have the same symptoms...vag codes say abs speed sensor intermittent.
Old 11-29-2004, 12:20 PM
Junior Member
marcodant's Avatar
Default guys if cleaning does not work
then check for opens.. I had a wire that worked and when I mad turns or bumps it tripped the sensors. But not always.. Sometimes it was perfect no errors.. If you do have a open in the wire it is easy to sut and splice in a new 18-16 gauge wire.. just make sure you make the connections water tight.. Hot glue works great..
prijedor
10-30-2007 07:26 PM
prijedor
11-14-2006 03:08 AM
cgt83
Audi 100 / A6 (C4 Platform)
09-26-2005 04:41 AM
pearlm30
02-07-2004 01:09 AM
atrak
10-15-2002 03:45 PM
Quick Reply: ABS Light came on this morning. Time to clean the sensors I guess.
