Sponsored by:
Sponsored by:
Rain/Light Sensor help
Old 11-22-2019, 10:17 AM
dhorse666's Avatar
Default Rain/Light Sensor help
Hi,
‘I’ve upgraded my light sensor to a train and light sensor but I’m lost as to whether I’ve put everything in the right place as I’ve got a few issues.
I’ve put the wire from sensor to J519 I’m lost as it’s still not working and the lights have some issues.
can anyone help please?
Old 11-22-2019, 10:59 AM
mcs
mcs's Avatar
Originally Posted by dhorse666
Hi,
The J519 module must be changed to a later one from a facelift car, (mine is revision S I think and I removed an E module)
After this you have to remove all light sensor coding from the roof module.
Old 11-22-2019, 11:21 AM
dhorse666's Avatar
Yes I’ve done that.
replaced with a Q variant and taken 512 from the roof module as per previous posts.
gives me a 01520 error on the rls - no signal/communication - intermittent
also the sidelights show a short/blown error
When I turn the lights on they flash up then turn off again. I then -turn them off and on again and they stay on.
was trying to find pictures of what to do but the posts are too old and the pictures have disappeared
I’ve got VCDS and looked at the coding but am still at a loss.
I’ve taken the power from the original light sensor power
Old 11-22-2019, 01:43 PM
mcs
mcs's Avatar
Yes I’ve done that.
power and earth are fine to come from
the light sensor,
how did you connect the data wire?
Old 11-22-2019, 02:22 PM
dhorse666's Avatar
I disconnected the data wire (green) in the roof electronics (038) and connected a length of wire from there to pin 31 of J519, spliced in I should say (09)
Old 11-22-2019, 03:20 PM
mcs
mcs's Avatar
This is the yellow/white wire?
It must be a splice.
That's the only hardware changes. If your coding is correct, then the RLS may be defective.
Old 11-22-2019, 04:17 PM
dhorse666's Avatar
Yes spliced in so the new wire is connected to the wire as it enters pin 31 on j519.
suspected the sensor may be faulty too but wanted to double check all avenues first.
was looking for pictures of the wiring to make sure I’d done everything right too
Old 11-25-2019, 01:34 AM
storka's Avatar
yes its a pain.
most of the photos and how tos are long gone off the net.
Had a lot of drama with mine but was coding.
still get error codes
Old 11-25-2019, 09:54 AM
dhorse666's Avatar
I think I may have solved it with coding but will check later once I take it on a run
Old 11-25-2019, 09:56 AM
dhorse666's Avatar
Also I’ve got an issue with my alarm horn but I’ve started another post for that if you have any ideas
mcs
10
03-09-2022 08:22 PM
audi-a8
20
08-19-2019 05:59 AM
Anotaren
A4 (B7 Platform) Discussion
12-12-2015 03:07 AM
snickers
12-01-2004 04:31 PM
Quick Reply: Rain/Light Sensor help
