Sponsored by:
Sponsored by:
2006 a8 oil cooler
Old 05-17-2014, 12:37 PM
sargemech's Avatar
Default 2006 a8 oil cooler
hey everyone this is my first post. I am trying to remove the oil cooler from 4.2l a8l. I cannot access the top left bolt for the cooler. there is a metal coolant pipe in the way. I removed the bolt holding it into cooler, but it still will not move enough for me to get to last bolt. i cannot see where it goes to loosen at other end. can anyone help me?
Old 05-17-2014, 01:52 PM
ltooz_a6_a8_q7's Avatar
Default Is this the metal pipe you're talking about?
<a href="http://www.dognmonkey.com/audi/2000-a8-40v-oil-cooler-plastic-pipe-replacement.html">This is how I did the 40V 4.2L D2 Oil Cooler</a>
Cheers and take pictures please,
Louis
Old 05-17-2014, 01:55 PM
sargemech's Avatar
no. the pipe goes in on the top, not the side. it hits the exhaust stud before it comes out. wanted to see if there is another way before i try to remove stud.
Old 05-17-2014, 01:58 PM
let me print out the oil cooler replacement to see if you have to remove the exhaust
Old 05-17-2014, 02:09 PM
Default it does look like you have to remove the exhaust
<a href="http://www.dognmonkey.com/media/audis/06a8/oilcooler/remove_exhaust.pdf">remove exhaust</a>
Old 05-17-2014, 02:18 PM
sargemech's Avatar
not what i wanted to see, thx for the info.
Old 05-17-2014, 02:25 PM
sargemech's Avatar
when i click on the part for removing the cooler it shows the other kind, not the one i have. is there possibly another process for my model. coolant line goes on top of cooler, not the side.
Old 05-17-2014, 02:28 PM
the pdf may show the coolant pipe that you're talking about
Old 05-17-2014, 02:34 PM
Default coolant pipe to oil cooler
<a href="http://www.dognmonkey.com/media/audis/06a8/oilcooler/coolantpipe.pdf">coolant pipe to oil cooler</a>
Hope this is the one.
Louis
Old 05-17-2014, 02:41 PM
sargemech's Avatar
yes that's the one. It says i have to remove engine. is there a procedure for manifold removal without pulling engine. not equiped to do that in driveway.
Quick Reply: 2006 a8 oil cooler
