Sponsored by:
Sponsored by:
2007 S8 passenger door soft close feature dead
Old 05-06-2014, 11:40 PM
westcoastS8's Avatar
Default 2007 S8 passenger door soft close feature dead
The close assist feature stopped working. The motor is silent, so I don’t think it is a broken cable issue.
Service records from the previous owner showed the dealer had replaced the driver’s side a number of years ago .It mentioned doing a VAS5051 scan that showed the motor working properly but the micro switch was not reading.
Using my VagCom I could not find any fault codes nor any output tests for the motor or micro switch. I would like to know what I need to replace and order the parts before I tear apart the door.
Any experience in diagnosing the failure mode?
Old 05-07-2014, 09:49 AM
Gary Knox's Avatar
Do a search on this forum for 'soft close door'. I had one that wouldn't soft close, and when the mechanism area on the door itself (latch area) was sprayed with Kroil it now works 100%.
Old 05-07-2014, 11:53 AM
Thanks
I did the search and tried the spray method also tried putting it into and out of Transport Mode which worked for another poster, no luck with either.
I am pretty sure it is the motor or micro switch or both and would like to figure out which before gutting the door.
eldoj
04-24-2006 09:12 AM
calbear92
02-19-2006 10:28 AM
ABDCTTD
08-14-2004 05:53 AM
Neutron
05-28-2003 11:50 PM
808grouch
08-11-2002 07:45 PM
Quick Reply: 2007 S8 passenger door soft close feature dead
