Sponsored by:
Sponsored by:
Battery, Alternator, or Starter?
Old 08-03-2012, 02:42 PM
  #11
Mister Bally's Avatar
If someone determined a 40 A current draw and you dont hear a motor on or humming (example seat adjustment switch stuck and a motor cutting in & out because of a thermal protector or the radiator fans running; Try this: Remove bottom cover from engine. Charge battery by driving/idling/ external charger. Park car in garage for evening. Set an alarm clock etc. After four hours or more when the engine is cold, put your hand on the Bosch alternator. You will find it toasty warm and your battery drained. Common failure mode.
As an option, just hook up a battery charger so your battery is not drained. Next morning everything except the battery should be stone cold. Your alternator won't be. Now, I have had it intermittent. Some mornings all was well, others completely dead battery. New battery made no difference so imagine how happy I was when it was discharged. That's when I tried the charger trick. 2nd morning toasty warm alternator. I replaced it. Typical symptom of a leaky, but not fully shorted diode.
One other thing, The MMI battery level indicator is not the most accurate thing, I hardly every look at it. More of a curiousity thing.
Old 08-03-2012, 07:34 PM
  #12
K9COP's Avatar
Default Good advice all....
Thanks. Wouldn't want my baby (and dem sick rims..) torched in the morning....
K9
Old 08-04-2012, 01:12 PM
  #13
bananapeel's Avatar
I removed the fuse for the dension gateway 500. It was plugged into the auxiliary radiator fuse (slot 38). Don't know if that means anything since I don't know if the aux radiator runs since it doesn't have a proper fuse. I'll let it be for a couple hours and continue on to another suggestion if that doesn't work.
As far as removing the bottom cover from the engine....I don't know how. I'm not really a car guy beyond the minor stuff that everybody should know how to do. I also don't have a garage; it's parked in my driveway.
Old 08-04-2012, 04:07 PM
  #14
Six large 1/2 turn aluminum screw bolts and two plastic ones in each front wheel well. You should be able to remove them by placing the car in lift mode if you are not physically too big. Otherwise you'll be paying someone to troubleshoot. Maybe you have a mechanically inclined neighbor or friend that can help. I say it is the alternator since I have had a few Bosch ones fail this way. Also note that the alternator "idiot light" which is supposed to illuminate with ignition on but motor not running will usually not illuminate when you have this problem . Not many individuals catch this. Good luck.
Old 10-23-2012, 05:18 AM
  #15
bcvickers's Avatar
Was this ever resolved? If so I'd like to hear the resolution as I think I'm having a similar problem.
Old 01-18-2017, 11:43 PM
  #16
Hartonen's Avatar
Resolved yet?
Old 01-19-2017, 10:39 AM
  #17
Shark_V8's Avatar
OP ended up filling his trunk full of batteries and creating a 220V plug-in @ home. Swapped the nameplates to Tesla.
doublesin
01-25-2014 07:12 AM
ltooz_a6_a8_q7
12-10-2011 07:15 AM
deacon68
04-23-2010 04:17 PM
cclcal
06-16-2009 09:55 PM
skiquattro
08-04-2006 09:28 AM
Quick Reply: Battery, Alternator, or Starter?
