Creepy Rear Window - Creeps open!!
This is a strange one. If I open a door when parked overnight, (say to grab my phone), the rear window starts to click, click, click about few mm at a time.
Come back and the dang thing is fully opened. Buttons are useless at this point.
Also has done it when just starting out. The window will not control until say 10 minutes into the drive.
Gotta be the door or window module, not liking the new temps, but have not had a chance to scan or pull the panel. Too busy.
Have to work on my starter now also (my plan is to inject lube into the solenoid piston), as the EPC is showing up now that we are in single digit DegC morning temps.
Are the fuses for the rear doors separate? I'd pull it until you can sort it out. It's sounds like an issue on one of the controllers, but it's hard to say which one. It's not necessarily the one on that door, since you can roll down that window from several places.
Pulled codes I have a door control module fault all over the place. Anyone have a part # handy?
Ebay says OEM RIGHT REAR DOOR INCIDENT CONTROL MODULE
PART #: 36129658
Incident?
Also have an alarm horn fault...
PART #: 36129658
Incident?
2004 2009 Audi A8 L Quattro D3 Rear Right Side Power Window Lifter Motor | eBay
thanks!!
part on order. Might be due to water ingress but I'll have the part ready when we pull the door panel.
It's actually a bit of a treat to see parts so easy to access, with so many of these cars being totaled and parted out.
I had gotten used to Audi V8Q, Volvo R, Porsche GTS - hard to locate & takes a lot of time.
installed part - now 2 codes
the part was from a 2007, with soft close and a power child lock no doubt, so my harness (2003 build.2004 model) is spitting codes:
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Control Module Part Number: 4E0 910 802 A HW: 4E0 959 802 C
Component and/or Version: Türsteuer.HR BRM003 0100
Software Coding: 0032364
Work Shop Code: WSC 02313 785 00200
VCID: 1E7015ABC92F2FB2A6-804A
2 Faults Found:
02131 - Child Safety Lock Motor
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 2
Fault Frequency: 0
Reset counter: 92
Mileage: 181584 km
Time Indication: 0
Date: 2016.10.20
Time: 18:13:44
02128 - Door Closing Control Module (J657)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 0
Reset counter: 92
Mileage: 181584 km
Time Indication: 0
Date: 2016.10.20
Time: 18:13:44
Other than that works well so far. Will look to see if I can disable the two functions above in VCDS?
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 92
Mileage: 181584 km
Time Indication: 0
Date: 2016.10.20
Time: 18:13:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 92
Mileage: 181584 km
Time Indication: 0
Date: 2016.10.20
Time: 18:13:44
Installed the same CODING # as the other current 3 door motors, no more faults of course.
The electronic module can easily be separated from the winder motor, BTW. So that is why some parts on ebay may not have the motor.
CMillA5
18
05-07-2019 09:16 AM
