ESP/ABS & Parking brake malfunction
#21
have same abs problems like you. its a nightmare. did the rebuilt off the ABS but was no good. got a used one from eBay for 210$, was no good. got my refund. got second abs from eBay and this time its working. (after coding the unit, took 4 hours, not easy)
then found some wires are no good.( insulation no good). my mechanic drove the car today and all was perfect, till 2 hours later the abs light comes on, but then goes away. we think more wires are no good. still working on it. will info you. good luck
#22
I think I just joined the club. Was driving, the Abs and Parking Break errors came up. Pulled the car to the side and restarted it, errors went away and smooth sailing; however this has happened at least 7-8 times in the past two months and each time restarting the vehicle seems to get rid of the annoying errors. I haven't hooked up a VCDS, will probably do that tomorrow, hopefully its just the Abs module that needs a reset and that's all.
#23
I just received my abs module back from 'cheap abs' and they said it was not a repairable type. Apparently they deal with Bosch, Wabco and a few other but not the siemens module from my car.
#24
When my dash errors began they would pop up once in a while also, then they started appearing daily.
#25
#27
Is there a second module on the 2007 model? At cheap abs and module repair pro the abs modules are located in the engine bay and look completely different from the one located under my battery in the trunk. I think I sent in the wrong part.
#28
#29
Yeah, if you got it from the trunk you sent in the wrong part to cheapabs. What you're looking for is under the hood and quite easy to get to. It is connected to the master cylinder, has the harness coming from it.
#30
Thats what I get for moving hastily, I was dealing with the parking brake module, duh! Can the car can still be driven if the abs module is removed?
