Front speakers cuts/dies when turning up
Hi!
On my 2004 A8, the front speakers cut/die when I turn up the volume,
if I turn down the volume, sometimes the front speakers turn on again, but most times they stay quiet until I let the car stay shut for a while.
Any ideas? Quite annoying not being able to listen to music properly.
Thanks
Thanks
Hi! And welcome to the forum!
I would guess that some AMP could be faulty. Check bildelsbasen.se to find a used one or ebay.de. I think you can find the amps in the trunk. The opposite side of the battery.
Kul med en till svensk!
Try to scan the sound system first for error codes. I sorta the same problem but in the reverse order. Only the right side of my speakers work until I turn the volume up high then the left side starts to work. It is caused by the Amp being in component protection.
Silly question; Are all of the speakers stock? If not, return them to stock units otherwise all bets are off.
If stock, a diagnostic scan with VCDS or the real VW/Audi tool is the proper way to diagnose this.
Banned
Banned
2004 2006 Audi A8 Bose Trunk Mounted Amplifier 4E0035223B Amp | eBay
04 05 06 Audi A8 D3 Bose Amplifier Amp 4E0 035 223 A 0653 MDL 373 009 021 | eBay
