Having some problems with my car. This is what I got with the vagcom scan.
#11
If you want to try one other old school diagnostic since scan doesn't seem to be much help so far, leave MAF unplugged and try some Ether. Assuming it starts and sort of runs if you keep goosing it with a quick spray of Ether every few seconds, it is also suggesting you have a big vacuum leak or a basic fuel problem.
#12
Thanks guys.
Will start taking some intake hoses off and looking for a leak. Is there a diagram of all the vacuums lines and hoses?
Thanks again.
Thanks again.
#13
You should have an underhood sticker with the basic vacuum schematic. Given your issues it would not be just a small line--something major like the multi inch rubber connections between the MAF and the intake, or some of the big hose take offs in that area like that go to power brake unit and suck valve (aka suction valve and various other names--Y shaped, basically a splitter Y with a one way check type function. You will find hoses like these between back of engine and firewall, on drivers side. Or other pretty obvious stuff where you hear air sucking noises like a broken intake or some such. Also look at the PCV valve--that ginormous round plastic thing toward back of intake area sitting fairly high up.
Remember though, it could also be fuel starvation. The Ether test idea may help give you some sense if it is on the fuel side. Old school used to be dribbling gas down the carb, but no longer practical with long and difficult to access intakes.
#14
Did some looking around for a broken hose but found nothing. The only thing that I found is 079133424s. I am not sure what that is, but the plastic on top that the hose goes over it is broken.
https://www.ecstuning.com/Search/079...FYqPfgodDYUAlg
#15
Sounds like you might have found your leak. The product description is pretty telling: This adapter is located on the rear of the intake manifold, just after the throttle body, on your vehicle. It ties into the vacuum system of your vehicle and allows idle air through when the throttle body is closed.
How are you testing for vacuum leaks? Best way is carb cleaner or an unlit propane torch.
#17
#18
I can't really make out the other part either, though IIRC the name of that part would fit your code it seems. My C5 4.2 didn't have a part like that. Also, I don't know from your comment if you mean it is cracked through to a functional part of it, or just some cosmetic mounting type tang or some such is cracked off that would not compromise the vacuum sealing of it.
#19
