Help Issues with 2006 D3/A8 Tail Lights
I am the proud owner of a 2006 Audi A8/D3 Oyster Grey with 19 inch factory rimes, my tail lights seem to be giving me some issues. When the lights come on )Auto mode) or lights are fully turned on the tail lights are not working correctly. The Passenger side works fine, the upper and bottom portion of the LED lights flash when I signal and are bright when flashing. The DRIVER side tail light is brighter up top than the passenger side and only the lower portion of the light flashes when the signal indicator is on, as again the upper portion of this light is very bright. I have taken them apart, no water inside, but frm a distance you can see how the passenger side flashes and looks good the driver side flashes but is outshined by the uppor portion of the LED. If anyone has any ideas or has experienced this please let me know ho you remedied this problem if need be I can include a video or pictures.
Ghost 77 or
Ghost 77 or
Banned
UNPLUG THE INNER
Hello Ghost,
My drivers side outer tail light did that about 15 months ago, and it turned out that it was the inner trunk mounted tail/reverse light that was at fault, the inner unit had moisture and shorted the outer, if you unplug the inner and the outer works correctly, then you know, mine is back to the same problem as of this week, they have some sealing flaws and get wet inside, this will be the third inner on my driver side, I will most likely silicone the new one on all sides.....
Johnny J J
Johnny J J
Sounds like a short. I recently replaced my taillights because one was leaky and i wanted the new design on my car. If you want to buy them for a fair price. They work perfectly with only 6-10 leds being out.
Hello Ghost,
Johnny J J
Johnny J J
Johnny I took the lamp apart and the thing had about 2 teaspoons of water in there. I wanted to leave it apart but instead got all the water out, resealed it and hope just the heat and use will dry it out and correct the issue. Humongous pain in the ***. I can imagine it is for you especially being in Jersey. I'm from NY so I know Jersey ops can be a pain in the ***.
I think that will be my long term solution but fr nw if I can just get them working properly. have found the retrofit from VAG on ebay plug and play set for $1000. If I can find them cheaper I will go for it, but for now stashing money aside for the ones that I found.
I just need the outers but let me know how much you want--PMing you now, not to hijack
Salty I will let you know, i drained all the fluid hopefully it wrks right after it dries up. Had the same issue on the passenger side and after draining it, it took about a day it was working correctly but now the driver side is doing it.
New user
Ghost 77 or
Ghost 77 or
