Sponsored by:
Sponsored by:
How to turn off TPM?
Old 09-23-2014, 06:04 AM
  #21
Brozee's Avatar
Originally Posted by audi44023
can I buy a cheap vag-com from China or do I need to buy the real McCoy?
Thanks
You'll need the real one. Not only for this situation but for all going forward.
Old 09-23-2014, 06:05 AM
  #22
Brozee's Avatar
My mmi is not working- at least the center dial. 08 A6. Tire sensor is on, cant reset because I can't toggle screens with center dial. Is there a way to reset tire sensor manually if I cant use mmi?
Also if your MMI isn't working i think that resetting the TPMS light is the least of your concerns. Get that MMI fixed first then tackle the TPMS issue. I made this post to temporarily disable the sensors and/or use it for disabling the system to use with a winter set of wheels for those who didn't want to buy two sets of sensors for summer/winter wheels.
Old 09-23-2014, 06:30 AM
  #23
1Wasserwerks's Avatar
That's exactly what I'll be using it for in about 2 months.
Old 09-23-2014, 05:48 PM
  #24
05SilverA8's Avatar
If you do get a knock-off vag-com it may actually work once or twice before it dies. Don't expect it to work more than once though, and they usually are several versions of software behind. Buy a real unit and it will pay for itself after the first or second time you use it.
Old 09-23-2014, 05:53 PM
  #25
jakematic's Avatar
Yep... that's one of the indicators of a stolen version.
12.12.3 and 14.8.1 are the current versions along with firmware 1.93.
Yep.
And if you don't use it much you can re-sell it for nearly what you paid
Old 12-04-2014, 01:25 PM
  #26
parkrog's Avatar
Default Thank you
Changed codes you suggested for TPMS in Vag Com and system off! Put studded snow and winter wheels on! Thank you for advise. Rog
Old 12-04-2014, 01:28 PM
  #27
Brozee's Avatar
Did you use my thread to disable?
https://www.audiworld.com/forums/a8-...ccess-2835606/
Old 12-05-2014, 01:27 PM
  #28
parkrog's Avatar
yes used your codes on my 2006 A8. I have latest upgrade on MMI
Thanks again.
theunit
13
02-05-2008 04:04 AM
OC02ALLROAD
Audi allroad
01-22-2008 10:27 AM
SpeedyG0127
10-03-2006 03:12 PM
SpeedyG0127
10-01-2006 07:42 PM
TJR178
08-09-2006 12:50 PM
Quick Reply: How to turn off TPM?
