My 2004 A8L 4.2 died after a normal journey
#11
Today I did some logical test work.
When I put the key in the contactlock the steering wheel get unlocked.
The starter is turning and engine starts and Die after 2 seconds.
With a scan today I found this:
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0C9525291
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4D05FECE1DD1E68D9-804A
12 Faults Found:
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster
18347 - Powertrain Databus
P1939 - 008 - Missing Message from Controller for Access & Start Auth.
18044 - Powertrain Data Bus
P1636 - 008 - Missing Message from Airbag Controller
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
P1650 - 004 - Missing Message from Instrument Cluster
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit - Intermittent
18284 - Valve for Torque Support Mount
P1876 - 004 - Open Circuit
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 -
Readiness: 0110 1101
Seems the Immobilizer is working (partly) otherwise it cannot block the engine start. I removed the Immobilizer and exchanged it with a spare one (let see what happen, I know that the car won't work because no match with Key), then nothing is working anymore, even the starter won't turn the engine arround so I put the original back in place. There must be a match with the key otherwise the steering kolom will not unlock.
The connector on the Immobilizer gives 12.5 V ground 0 Ohm.
Tested Electric II bordnet (J520, 4E0907280A ) is accessable by VCDS and can steer components with VCDS ( output sequense )
Electric I modul J518 works partly because I can turn my front Xenons on but blinkers won't work, I cannot access the modul by the gateway.
Maybe I must search into the direction of the ECU, I read some story on this forum about a Q7 with same problems only not that his cluster went dead.
Tomorrow I will remove the ECU ( difficult operation to remove the metal shield, must heat 2 bolts ) and will check if then there is access to the other not reachable moduls. maybe the ECU put some Gateway lines to ground.
I keep in mind that maybe from the not reachable moduls gateway ports can be blown. Aswell that I test without a cluster installed ! maybe this aswell give me no access to those moduls.
Maybe someone have a A8 open and can do test if moduls can be accessed when the cluster leads removed.
Coding: 0007773
12 Faults Found:
P1570 - 008 -
#12
Today I read an article about that some have problems they have an aquarium in the waterbox ( the area from the left to the right where the ECU and pollenfilter is mounted ) I don't have an aquarium there but still its a bit wet there.
Under the ECU is a box with electronics to ( relay's ) inside I will inspect aswell and test the components.
#13
#14
By the selfstudy I notest that the car has a left en right CANbus system, you find the CANbus junction points above the left and right fusebox. (SB/SC)
So if you read the Code from my car from not attainable moduls they from the leftside. mmmmm it get interesting....we close. Some test tools are available to check CANlines from those junction points, called VAG cable 1598/38
#15
Hello Guys, today a lot progress,
I took the canbus plugs out of the junction connectors on left and right side, I cannot see any corrosion on the pins, anyway a swap right plug to the left en the left to the right side, unplug and plug them several times to get corrosion away if any.
Then I notest my lights in left doors working again.
mmmm....I start the car and supprised it RUN !!! without cluster !
Installed the cluster and wallaaa it works aswell.
I can lock the car again.
I coded some moduls and here is the last scan below.
Code:
VIN: WAUML44EX4N012605 License Plate: 10-2-2016----10:50AM Mileage: 186700km-116010mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 72 75 76 VIN: WAUML44EX4N012605 Mileage: 186700km/116010miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: Not registered 0001 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 75-Telematics -- Status: Malfunction 0010 76-Park Assist -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.lbl Part No SW: 4E0 910 560 A HW: 4E0 907 560 Component: 4.2L V8/5V G 0070 Revision: 00000000 Serial number: AUX3Z0C9525291 Coding: 0007773 Shop #: WSC 02313 785 00200 VCID: 1F4D05FECE1DD1E68D9-804A 1 Fault Found: 18284 - Valve for Torque Support Mount P1876 - 004 - Open Circuit Readiness: 0010 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 E HW: 09E 927 156 A Component: AG6 09E 4,2L5V USA 0110 Revision: 00000001 Serial number: 0022839 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 24470A12E77BF23ED0B-8071 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 E Component: ESP 5.7 allrad H29 0420 Coding: 0007597 Shop #: WSC 02313 000 00000 VCID: 21490306F869E716BBD-8074 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 A Component: FBS AUDID3 H03 0130 Revision: 01303703 Serial number: AUX3Z0C9525291 Coding: 0263168 Shop #: WSC 02311 785 00200 VCID: D8BFEEE26BB3E6DE0C3-808D Subsystem 1 - Part No: 4E0 905 852 C Component: ELV 1734 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H06 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3940448 Shop #: WSC 00000 785 00200 VCID: 2345090EE275F506A91-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 P HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 346JW037506718 Coding: 0000016 Shop #: WSC 00000 000 00000 VCID: 3979CB6670F99FD693D-806C Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000023798 Subsystem 3 - Serial number: 0103.11.060000000100010059ÿ Subsystem 4 - Serial number: 010059ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 772 A HW: 4E0 820 043 B Component: Sitzluefter FS H01 010 Revision: 00000021 Serial number: 00000000028070 Shop #: WSC 00000 000 00000 VCID: 24470A12E77BF23ED0B-8071 Subsystem 1 - Part No: 4E0 910 772 A Component: Sitzluefter BFS H01 010 Subsystem 2 - Serial number: 898053000 Subsystem 3 - Serial number: HO17102003065A000000000023ÿ†89 Subsystem 4 - Serial number: 000023ÿ†898053000 000-SHO Subsystem 5 - Serial number: 000-SHO17102003065A00000000 Subsystem 6 - Serial number: 65A000000000027ÿ 1 Fault Found: 01857 - Air Outlet Sensor; Middle Left (G347) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 4 Mileage: 186700 km Time Indication: 0 Date: 2003.06.18 Time: 00:15:49 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0111101 Shop #: WSC 02311 785 00200 VCID: 2A5BE42A855F244EEA7-807F Subsystem 1 - Part No: 4E1 910 113 C Component: Wischer WWS D3 H60 0420 Coding: 00000255 Shop #: WSC 02311 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 E HW: 4E0 035 111 A Component: CD-Changer H44 0430 Revision: 00000000 Serial number: AUZ5ZBE7139877 Shop #: WSC 00000 000 00000 VCID: 1B3531EEDA05CDC6611-804E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 A HW: 4E0 959 655 A Component: Airbag 8.4E+ H09 0920 Coding: 0530707 Shop #: WSC 02313 785 00200 VCID: 24470A12E77BF23ED0B-8071 1 Fault Found: 01742 - Igniter for Knee Airbag; Drivers Side (N295) 002 - Lower Limit Exceeded - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 A Component: Lenksäulenmodul H12 0040 Coding: 0012241 Shop #: WSC 02311 785 00200 VCID: E5C1D7162CC14B36875-80B0 1 Fault Found: 01426 - Controls in Steering Wheel (E221) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 4 Mileage: 186700 km Time Indication: 0 Date: 2003.06.18 Time: 00:56:26 ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 950 B Component: KOMBIINSTR. VDO H44 0080 Revision: D13 Serial number: AUDID3C9004831 Coding: 0000003 Shop #: WSC 02136 444 10340 VCID: DCB7F2F21F8B0AFE28B-8089 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 174205 km Time Indication: 0 Date: 2012.10.16 Time: 21:07:33 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 A HW: 4E0 907 468 C Component: Gateway H07 0030 Revision: 07 Serial number: 02005039230A5E Coding: FCFE7BCC1B2304 Shop #: WSC 02313 785 00200 VCID: 2643101A9147002ECEF-8073 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 4 Mileage: 186700 km Time Indication: 0 Date: 2003.06.18 Time: 00:56:30 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 A Component: FBS AUDID3 H03 0130 Revision: 01303703 Serial number: AUX3Z0C9525291 Coding: 0263168 Shop #: WSC 02311 785 00200 VCID: D8BFEEE26BB3E6DE0C3-808D Subsystem 1 - Part No: 4E0 905 852 C Component: ELV 1734 4E0905852C ELV 1734 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 E HW: 4E0 907 553 E Component: LUFTFDR.-CDC H05 4290 Coding: 0025510 Shop #: WSC 00011 888 06946 VCID: 25411716EC410B36C75-8070 1 Fault Found: 00778 - Steering Angle Sensor (G85) 008 - Implausible Signal Freeze Frame: Fault Status: 11101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 4 Mileage: 186700 km Time Indication: 0 Date: 2003.06.18 Time: 00:56:24 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H06 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4071522 Shop #: WSC 00000 785 00200 VCID: 2345090EE275F506A91-8076 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H42 1060 Revision: 00000000 Serial number: 355KW037510884 Shop #: WSC 02313 785 00200 VCID: 3B75D16E7AC5ADC6811-806E 1 Fault Found: 00862 - Antenna for GPS Navigation (R50/R52) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 4 Mileage: 186700 km Time Indication: 0 Date: 2003.06.18 Time: 00:56:32 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 Component: Dachknoten D3 H01 0090 Serial number: 00000328300023 Coding: 0003989 Shop #: WSC 02313 785 00200 VCID: 1D313FF6C411C3F69F5-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E1 959 801 Component: Türsteuer.FS BRM005 0110 Coding: 0028196 Shop #: WSC 02311 785 00200 VCID: DEB3F8FA099718EE46F-808B No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040511110118 Coding: 0004857 Shop #: WSC 02729 823 28888 VCID: 285F1E229B53165EFC3-807D Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel H06 0050 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H02 0020 3 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 254 Reset counter: 4 Mileage: 135370 km Time Indication: 0 Date: 2003.10.08 Time: 00:37:37 01308 - Control Module for Roof Electronics (J528) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 25 Reset counter: 92 Mileage: 30225 km Time Indication: 0 Date: 2011.07.06 Time: 16:11:07 01505 - Bulb for Blinkers; Rear Right (M8) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 23 Reset counter: 92 Mileage: 30226 km Time Indication: 0 Date: 2011.08.18 Time: 05:37:32 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 H HW: 4E0 035 223 B Component: DSP-High D3/AUX H13 0370 Revision: Dev_D01 Serial number: 00000000463620 Coding: 0000016 Shop #: WSC 02313 785 00200 VCID: 224B0C0AFD6FFC0EA27-8077 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000023385 Coding: 0010101 Shop #: WSC 12345 123 12345 VCID: 1E3338FAC917D8EE86F-804B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E1 959 802 Component: Türsteuer.BF BRM005 0110 Coding: 0028196 Shop #: WSC 02311 785 00200 VCID: DEB3F8FA099718EE46F-808B No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0000531 Shop #: WSC 80093 222 18370 VCID: 1F4D05FECE1DD1E68D9-804A 5 Faults Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 3 Time Indication: 0 Freeze Frame: Voltage: 13.35 V Count: 61 02434 - Supply Voltage for Control Module for Left Channel 009 - Open or Short to Ground - MIL ON Freeze Frame: Fault Status: 11111001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 3 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: Voltage: 12.32 V Count: 112 02442 - Function Lamp in Control Head 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 4 Mileage: 186696 km Time Indication: 0 Date: 2003.06.18 Time: 00:17:43 Freeze Frame: Voltage: 13.35 V Count: 65 02443 - Control Head 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 3 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: Voltage: 5.07 V Count: 40 02435 - Supply Voltage for Control Module for Right Channel 009 - Open or Short to Ground - MIL ON Freeze Frame: Fault Status: 11111001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 3 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: Voltage: 12.32 V Count: 113 ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 02311 785 00200 VCID: E2CBCC0A3DEF3C0E627-80B7 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 C HW: 4E0 035 541 Component: TUNER EU/US/RDW H41 0290 Revision: 00000000 Serial number: 304JR037550378 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 204F0602F363EE1EB43-8075 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000001755 Shop #: WSC 00000 000 00000 VCID: 204F0602F363EE1EB43-8075 Subsystem 1 - Part No: 310 314 E05 G Component: von VA0 310314E05G Coding: 333130333134453035472056413033313033313445303547 Shop #: WSC 00011 888 06946 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM005 0110 Coding: 0028196 Shop #: WSC 02311 785 00200 VCID: DDB1FFF6049103F65F5-8088 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM005 0110 Coding: 0028196 Shop #: WSC 02311 785 00200 VCID: DDB1FFF6049103F65F5-8088 No fault code found. ------------------------------------------------------------------------------- Address 75: Telematics Labels: None Part No SW: 4E0 910 616 HW: 4E0 035 616 Component: Telematik USA1 0050 Revision: 00000002 Serial number: 0000ATD3005120 Coding: 0000005 Shop #: WSC 08252 444 52590 VCID: E0CFC60230E32E1E743-517A 1 Fault Found: 01531 - Emergency Battery 002 - Lower Limit Exceeded - MIL ON ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 HW: 4E0 919 283 A Component: Parkhilfe 8-Kan H07 0030 Coding: 0001208 Shop #: WSC 02313 785 00200 VCID: E0CFC60233E32E1E743-80B5 1 Fault Found: 01625 - Front Parking Aid Warning Chime (H22) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 4 Mileage: 186700 km Time Indication: 0 Date: 2003.06.18 Time: 00:49:21 End ---------------------------------------------------------------------
#16
well looks like your kessy and immobiliser are ok at least.
still a few of errors nothing terminal. probably clear them see what comes back.
A few will be from drained battery.
Valve for torque mount: I have that. I think thats normal as I think the early one were not wired or something.
Possible Symptoms
Hvac get that sometimes. g347 is part of the wiring in the vent grill
Address 47
Mulitfunction Comfort Control Module 4E0 907 289
Have you replaced this to get c/p ?
Possible Symptoms
- Malfunction Indicator Light (MIL) active
- Temporary Supply Voltage Interruption
- Steering Angle Sensor (G85) faulty
- Steering Column Control Module (J527) faulty
- Perform Steering Angle Sensor (G85) Adaptation
- See Vehicle specific Diagnostic Procedures for Details
- Check/Replace Steering Angle Sensor (G85)
- Check/Replace Steering Column Control Module (J527)
Address 47
#17
This can be solved to drive a block arround with car and it will learn itself the zero point, after can erase the fault.
Must check if J393 ( Central control Door electronics 4E0907289) is good now as I put a replacement in and changed it back with the original one.
Gateway wrong coded it says, i'm not sure what is exact installed in the car, in the trunk will read the sticker and can bring the right code in.
next step is to repair the MMI controll board in the console, some buttons (enter) not work due water leak from the sunroof more then a year ago.
#19
Or have you retro fitted something ?
#20
