P0491 and P0492
Try search first and let us know your findings/questions:
Google "P0491 site:audiworld.com" gave me 491 hits. Seems like plenty for a starting point... Using search built into this D3 forum's page (in the right hand corner of this very forum page) with these post listings shows a few, including the one in the past few months where I personally responded a fair amount. Google usually pulls far more than AW's search; you can fine tune it with A8 or D3 or whatever if you want.
In general, please exercise the keyboard a bit first and take time to get up to speed on info already so easily there.
+2 on previous replies
Additionally anyone with any diagnostics chops is going to want to so a complete, unmolested, Auto-Scan.
"P" codes are a generic standard provided as a courtesy by VWAG for backwards compatibility.
There is far more specific information available from a real scan.
and, for fear of being scolded, i have limited my posts
(some people seem to get annoyed that poeple are chatting, on chat boards)
Some people get annoyed when others don't put in some effort first.
And, as Jakematic pointed out, P codes are also a typical sign of second rate scan information, and that the poster is likely using a lower quality non VCDS device.
Trust me, I know a fair amount of practical information about the system, but when I feel I'm being used, I don't play. You've got 6 or 8 shots for the deepest info here, and already are on the radar with several of them. Good luck with it.
Here is the complete scan.
I am not being lazy. I do a lot of searching on the net to educate but it's a very very complicated car to me.
and as I've admitted it's an expensive car to maintain at times and I'm not the richest man at the moment.
It is the only car I have at this time.
so here it is at it was done by someone with a proper interface tool.
Sunday,26,October,2014,13:28:01:16630
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WAUML44EX4N015553 License Plate: 1234
Mileage: 163380km-101519mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 72 75 76
VIN: WAUML44EX4N015553 Mileage: 163380km/101519miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0CN528780
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4DC484CEFD2AE6827-804A
1 Fault Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0025539
Coding: 0000002
VCID: 2447CB68E79B093EDF5-8071
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2149C27CF8891C16B43-8074
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0CN528780
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8BF2F986B531DDE03D-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 4
Fault Frequency: 0
Reset counter: 127
Mileage: 126160 km
Time Indication: 0
Date: 2005.01.04
Time: 21:17:14
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 2345C874E2950E06A6F-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346KX037507960
Coding: 0000103
Shop #: WSC 93250 999 64609
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 301KR037529419
Subsystem 3 - Serial number: 7424.11.030000000000010054˙
Subsystem 4 - Serial number: 010054˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000030928
Coding: 1085697
VCID: DABB3590155F0FCE359-808F
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 209
Reset counter: 49
Mileage: 128907 km
Time Indication: 0
Date: 2005.02.01
Time: 13:12:41
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111104
VCID: 2A5B255085BFDF4EE59-807F
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02313
1 Fault Found:
01498 - Bulb for Parking Lamps; Right (M3)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 163376 km
Time Indication: 0
Date: 2004.06.06
Time: 12:56:04
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7278896
Shop #: WSC 00000 000 00000
VCID: 1B35F094DAE536C66EF-804E
2 Faults Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 199
Mileage: 133332 km
Time Indication: 0
Date: 2003.06.18
Time: 00:18:43
02095 - Component Protection Active
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 3
Reset counter: 37
Mileage: 162632 km
Time Indication: 0
Date: 2004.05.26
Time: 16:21:28
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H12 0040
Coding: 0012041
Shop #: WSC 93250 999 53700
VCID: E5C1166C2C21B03688B-80B0
Component: Lenkradmodul H03 0070
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H44 0080
Revision: D13 Serial number: AUDID3CN021320
Coding: 0000333
Shop #: WSC 93250 999 65003
VCID: DCB733881F6BF1FE275-8089
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 0200503B110F17
Coding: FCFE7BDC1B2304
VCID: 2643D16091A7FB2EC11-8073
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 127
Mileage: 126160 km
Time Indication: 0
Date: 2005.01.04
Time: 21:17:14
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 93250 999 80931
VCID: 2541D66CECA1F036C8B-8070
3 Faults Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 30
Reset counter: 37
Mileage: 159683 km
Time Indication: 0
Date: 2004.04.06
Time: 18:19:59
01583 - Leak in System Detected
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 3
Fault Frequency: 237
Reset counter: 11
Mileage: 154942 km
Time Indication: 0
Date: 2004.02.23
Time: 20:31:51
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 2
Fault Frequency: 249
Reset counter: 51
Mileage: 161914 km
Time Indication: 0
Date: 2004.05.13
Time: 16:50:30
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
5 Faults Found:
01453 - Driver's Seat Fore/Aft and Height Adjust Switch (E61); Forward
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 5
Reset counter: 51
Mileage: 163064 km
Time Indication: 0
Date: 2004.06.03
Time: 10:56:32
01191 - Motors for Seat Adjustment
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 91980 km
Time Indication: 0
Date: 2011.09.04
Time: 17:26:10
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 11
Mileage: 89788 km
Time Indication: 0
Date: 2011.07.29
Time: 08:50:42
01454 - Driver's Seat Fore/Aft and Height Adjust Switch (E61); Back
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 51
Mileage: 163064 km
Time Indication: 0
Date: 2004.06.03
Time: 10:56:32
01450 - Switch for Driver Seat; Tilt Adjust; (E222); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 51
Mileage: 163068 km
Time Indication: 0
Date: 2004.06.03
Time: 12:57:47
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H42 0740
Revision: 00000000 Serial number: 355KM037511180
VCID: 387F0F184B137DDE63D-806D
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000331700001
Coding: 0003973
VCID: 1D31FE8CC4F138F690B-8048
1 Fault Found:
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 30
Mileage: 162432 km
Time Indication: 0
Date: 2004.05.22
Time: 22:17:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028196
VCID: DEB339800977E3EE491-808B
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040311190246
Coding: 0064542
VCID: 275DDC6496ADE226FA7-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
7 Faults Found:
01505 - Bulb for Blinkers; Rear Right (M8)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 11
Mileage: 79554 km
Time Indication: 0
Date: 2010.12.04
Time: 15:35:03
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Reset counter: 11
Mileage: 136118 km
Time Indication: 0
Date: 2013.12.02
Time: 09:45:56
00984 - Left Tail Light (M4)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Reset counter: 11
Mileage: 114099 km
Time Indication: 0
Date: 2004.08.14
Time: 15:21:10
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 11
Mileage: 110536 km
Time Indication: 0
Date: 2004.05.05
Time: 12:26:17
01828 - Bulb for Tail-Lamp; Left
Freeze Frame:
Fault Priority: 3
Reset counter: 45
Mileage: 112094 km
Time Indication: 0
Date: 2004.06.16
Time: 14:24:30
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 3
Reset counter: 11
Mileage: 148131 km
Time Indication: 0
Date: 2003.12.20
Time: 14:42:58
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 218
Mileage: 157866 km
Time Indication: 0
Date: 2004.03.22
Time: 20:38:32
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 M HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0450
Revision: Dev_D01 Serial number: 00000000546392
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000028129
Coding: 0010111
VCID: 1E33F980C9F723EE891-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T08QWE
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 50
Reset counter: 43
Mileage: 160248 km
Time Indication: 0
Date: 2004.04.21
Time: 17:11:27
Freeze Frame:
Voltage: 13.15 V
Count: 236
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 9.42 V
Count: 61
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: E2CB0D703D0FC70E6D9-80B7
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0480
Revision: 00000000 Serial number: 304KL037553116
Coding: 0000002
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 162981 km
Time Indication: 0
Date: 2004.05.31
Time: 18:54:16
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000005308435
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1310310247
Coding: 303030393135313035414B56413031333130333130323437
Shop #: WSC 00000 128 00289
3 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 143722 km
Time Indication: 0
Date: 2003.09.24
Time: 12:32:52
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 147718 km
Time Indication: 0
Date: 2003.12.15
Time: 13:52:10
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 147718 km
Time Indication: 0
Date: 2003.12.15
Time: 14:29:45
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028196
VCID: DDB13E8C0471F8F650B-8088
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3006547
Coding: 0000005
Shop #: WSC 93250 999 83976
VCID: E0CF07783003D51E7BD-5140
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000333000100
Coding: 0001208
1 Fault Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 205
Mileage: 146104 km
Time Indication: 0
Date: 2003.11.20
Time: 16:12:30
End ---------------------------------------------------------------------
Thank you for the complete scan.
As you'll see it's an amazing tool and provides a mountain of information.
It's a bit of an old scan, and typically we recommend you clear all DTCs (codes) drive the vehicle and see what returns.
Here's my quick and dirty analysis:
Interestingly I don't see any of the SAI codes you are asking about.
Suggest fixing any obvious issues, clearing existing DTCs, drive the vehicle a few times, and post a new scan.
As MP said, P codes from generic code readers are of little value on a vehicle this complex.
You will need to use VCDS to run output tests in some cases as well.
- ignore N145
- G201 is concerning, but may go away once cleared
- ignore key issue with Kessy, probably battery related
- G65 might be an issue, check after clearing
- M3 is probably a blown bulb
- you CD changer is from another vehicle and I suspect your audio is cutting out every 2 seconds - only Audi can remove CP
- we already know about level control issues
- driver seat has some electrical problems, bad switch or wiring
- intermittent voltage problem with sunroof - could be wiring
- alarm horn may need replacing
- a boatload of bulb errors - could be burned out or wiring
- ABS is complaining due to sensor
- you need new brake pads in the rear
- IF amp may have corroded connections
- system shut things down to protect the battery - Quiescent mode [see my post on locking the vehicle when not in use]
- ignore or disconnect telematics - that's OnStar
- wiring issue for parking sensor - corrosion or break likely
+1; I don't see the secondary air codes/issues either
Lots of really old stuff in the scan--even ignoring the listed dates that seem goofed up, the miles (kilometers) entries are widely varied. Clearing it will slimplify what issues are still current and have not already been dealt with or gone away.
Secondary air codes should not go away without clearing the ECU module, so I don't get that.
