Rain/light sensor
#21
That is very interesting, especially if you haven't seen an A8 with auto lights without auto wipers. I will go hook the car up again tonight to see what I can find out. Do you know if there is a test or function that will show the part number for the sensor/sensors in VCDS?
So I swapped the central elec 09 module for a newer one, and it works. You will have to run the calibration for the steering wheel also.
I have a light only sensor here too. But obviously no relevant now.
#23
Can you show me where the code/part number is located I am not sure how to access subsystems. I will go start and dig around a little. Also could you or someone else show me the coding for 09 Cent. Elect. ILM Fahrer?
#26
When you scan your car you get a report with error codes etc
Saved on note. That's what's needed.
I will get to my pc soon and send you mine.
Or someone else bored ??
#27
AudiWorld Wiseguy
The rain/light sensor is integrated into the same sensor, but they have different part numbers depending on if it's just a light sensor, or rain and light sensor. The controller it connects to is also a different part number for the rain sensor version with different wiring between the two.
In short, it's not something that can just be turned on by coding. You need to have the correct hardware installed also for it to actually work.
rainnael (11-15-2022)
#28
#29
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0123111
Shop #: WSC 02313 785 00200
VCID: 3663C05A41E770AE7EF-8063
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0040
Coding: 00139548
Shop #: WSC 02313
Coding: 0123111
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
#30
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Component: ILM Fahrer H12 0170
Coding: 0020001
VCID: 2C5CB3DA8FDC2178ADD
Coding: 00000036
Shop #: WSC 02313
previous post auto lights and wipers
this post before without before retro fit
Coding: 0020001
Coding: 00000036
Shop #: WSC 02313
