Ready to change my upper control arms
$38 for 6 bolts and 6 nuts? What? I think I'm going to use the old bolts and nuts if they don't break.
By the way, the rear bolts seem to be pretty long, do I have to remove the shocks like D2 to take these 2 CA bolts out?
Let's see the little vibrations when going over the bumps will be gone or not.
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
As posted a lot already, you loosen three bolts from under the hood that hold the strut plate area and drop the assembly an inch or so, plus so you can move it around some. You don't remove them, jut back them out a good amount. But you don't need to take it out at all. That's just extra work and risk of damage to air system. Also as posted before, if you are doing the arms I would do the sway bar links if not done already; at least inspect them. Those are yet a few more bolt sets, though the Lemforder OES's come with some nuts already; approx. $65 for a set of two shipped.
MP4 thanks so much for the tips
I really need it... Yes, not to remove it, it will be great.
I didn't buy any of those pins.
Hopefully, the hood cables don't snap on me before I design a powered solenoid to open straight at the latch without cables.
Cheers,
Louis
Cheers,
Louis
As offered before, I'm just on on other side of the bridge from you (as in, "M.P."...) if you get stuck, aren't quite sure of steps, things to look at, etc.
Meantime, ours is open.
Delay until next weekend... Mother's Day and all
Thanks MP4, I'll let you know next week.
I did the D2 before, looked under the car, the bolts and nuts are looking fine. I'm sure it will be a breeze (wishful thinking). All the work I do to the car, I do read your tech gurus posts before I start, so I'm well prepared.
Thanks all and Happy Mother's day to all,
Louis
PS: today cook for all family mothers... a little busy.
Louis
AudiWorld Wiseguy
Just lubricate the latches and cables and the risk of a snapped cable pretty much vanishes.
did anyone has a lubrication procedure on these latches?
It's not the lubrication - it's the dinky little cable and the floppy spring loaded splitter cable box.
Have you tested the force needed to release the latch? there are 2 of them and this box with friction itself + spring + over pulling force of a macho mucho man = this little dinky
cable. Have anyone tested the maximum force this little cable can sustain? Jolt force is much stronger than linear force, so don't test this cable with linear force.
Where do they break? I don't think it's the cable itself, it's where the cable ends that are weak.
Now, retrofit the whole system with thicker cables and stronger ends, then I'll buy.
Cheers,
Louis
