Sponsored by:
Sponsored by:
Real time help, stuck at work.
Old 08-16-2016, 03:23 PM
Doc_A8's Avatar
Default Real time help, stuck at work.
2006 a8l will not start, does not recognize that it is in park. Where is the override?
Bigger issue... Anyone have this before?
Old 08-16-2016, 03:49 PM
Junius's Avatar
I have never heard of this before in an A8 but I did hear a few stories with C6 generation A6's
Old 08-16-2016, 03:50 PM
Doc_A8's Avatar
Found the release. No start in N either.
EPC malfuction? Now what?
Old 08-16-2016, 03:53 PM
Junius's Avatar
From what I remember, it may be a sign of either a failing brake light switch
Old 08-16-2016, 04:01 PM
CobraCommander's Avatar
Are you trying to use the start button or the key? Try exiting, locking the car and reentry...maybe the car needs to go through that cycle again.
Old 08-16-2016, 04:02 PM
Junius's Avatar
Or transmission control module from some of the A6 posts I have seen. It's not starting in Neutral either? Try holding the gear selector in between neutral and drive and try to start it that way.
Old 08-16-2016, 05:20 PM
MP4.2+6.0's Avatar
Besides fiddling w/ trying to start, best guess would be brake pedal switch. Known failure point, cheap to buy part. And if it does not see brake depressed even if in P or N, it won't start. Not 100% sure how to check, but a guess is if you step on brake the brake lights logically won't go on either.
Old 08-16-2016, 05:30 PM
Doc_A8's Avatar
Ok, got her home.
Did more reading that suggested the brake light switch. So, because I have a pretty extensive background in shade tree mechanics, I went and tapped the area by the switch firmly, twice.
It started.
So, I drove it home- parking brake malfunction indicator on the dash the entire way home. Strangely, also no cruise control.
But I can now leave it somewhere safe while I order the brake light switch. I found it for about 18$ from ECS.
markremi (02-19-2023)
Old 08-16-2016, 05:31 PM
Doc_A8's Avatar
PS, thanks guys.going to go order that switch and will pull a VCDS later.
Old 08-16-2016, 06:09 PM
MainelyA8's Avatar
Glad you got it sorted! This thread makes me want to preemptively replace mine.
Quick Reply: Real time help, stuck at work.
