Sponsored by:
Sponsored by:
Tail lights, anyone?
Old 12-15-2019, 02:25 PM
Andres Serrato's Avatar
Default Tail lights, anyone?
Hey everyone I'm looking to see if anyone has any spare tail light assemblies for an 04 A8L my light was cracked and I barely put pressure on it and it popped witch was weird but it broke -___-
if anyone has any for sale let me know thanks.
Old 01-04-2020, 04:18 PM
2015 A8L TDI
Dville's Avatar
lemme know if you are still looking.
about to take mine out replace them.
Old 01-04-2020, 06:23 PM
The Transporter
a_very_naudi_guy's Avatar
These things break all the time, in some way or form. I've had to replace both assemblies because of the same cracking, but now what I've got going on is an electrical "gremlin" that allows the rear passenger far-side tail light to illuminate sometimes, othertimes not. It's not the bulb. Not to mention that but for God knows whatever reason (VCDS website will confirm this) the starter will refuse to work from time to time needing a reset or a cool-down period before I can try to start it again and it is, no joke, caused by quote "a faulty Brake Light Switch can cause this".
I blame the crack leading to possible corrosion due to much humidity getting into the guts of the rear electric there.
Anyway, I believe a new single light assembly in good condition will run you ~$200 (maybe $150?) from a salvage yard and/or eBay. Also don't forget the vendor / user sales section here.
Regards,
Naudi
Old 01-05-2020, 08:51 PM
2015 A8L TDI
Dville's Avatar
I have a full set for sale.
I just upgraded mine
Old 01-07-2020, 01:34 PM
StrA8L's Avatar
Default Taillights
Old 01-07-2020, 01:35 PM
StrA8L's Avatar
How much would you like to see for these?
Old 01-07-2020, 01:42 PM
cal3thousand's Avatar
I need the passenger outer light. Looks like OP needs just the inner. PM sent.
Old 01-07-2020, 01:46 PM
StrA8L's Avatar
I need both inners.
Old 01-07-2020, 08:32 PM
nathanwind's Avatar
did you do the euro-spec ones, or the US one’s and run a jumper wire?
Old 01-08-2020, 02:21 PM
Brozee's Avatar
Let's not make the same mistake twice here. Don't tint these
Quick Reply: Tail lights, anyone?
