2013 A8L Off Idle Hesitation
#32
I have a 13' S8 and don't have the hesitation issue. Is the issue being caused by the turbos not spooling up in time for a good enough torque/power response? I had a 2009 BMW 750i before this, and that seemed to happen often. I would pull out to pass someone, and it was either no power or spill your coffee jumpy power after 1.5 seconds.
Does this problem happen when you use manual mode or sport mode? I could still replicate my problem in my 7 series using tiptronic. Is the A8 hesitating to down shift properly/select the correct gear, or is the power a lag from turbo?
#34
http://www.m3post.com/forums/showthr...ght=report+lag
I've been lurking on this forum since 2006, and still haven't bought an A8. Maybe next year.
#35
I test drove a A8 SC 3.0 and I loved it since it has a supergharger there is no lag, the power is right there, if I were to do it again I would get the 3.0 V6 I love the 4.0T and the 4.2 V8 is the best
#36
Agree on the 3.0 V6 comments. But... although the 4.0T's lag is annoying, its power and torque is quite amazing once you're moving. I don't regret upgrading over my 2012 4.2, and am hopeful that Audi comes up with a solution for the lag. Even a subtle improvement would be a step in the right direction and would make a difference. In the meantime, however, I'm afraid that any Smart Car or Prius has the jump on me when the light turns green. ):
#37
Has anyone had resolution on this yet?
Just noticed this starting on our '12 A8L over the past few months, intermittent at best, but alarming as hell when it does happen.
Taking it in tomorrow to have it checked, will forward all relevant detail from this thread, including earlier TSB too.
#38
#39
Do you have a TSB number or any specific information about the update you received?
#40
My dealer says there's no fix for this, and maintains the lag is normal and by design - it's intended to reduce the huge power of the engine so throttle tip-in isn't overpowering. This is a load of crap. This lag nearly resulted in me being t-boned recently, and is more than just a nuisance.
