Bass speaker rattle
Bass speaker rattle
I noticed some here have complained on a rattle when heavy bass sounds are played. I have the same from time to time and today I decided to check where it originated. Its coming from the speaker protection grill covering the speaker in the back, seems its slightly loose.
So before I start tearing things apart and probably break something does anyone know the correct procedure to remove this protection grill?
Same thing here. I had the dealer look at it and they described it as a loose parcel shelf. They said they fixed it and for the most part they did. I still hear it every once in a while. When it buzzes on mine, it buzzes over bumps as well as low bass.
Be careful with the speaker trim - it's a one time use only item.
See this thread: https://www.audiworld.com/forums/a8-...oofer-2858978/
The dealer tells me "don't turn the bass up past 5 and you're ok"... WTH?
I have this problem as well. Can you illustrate what you've described? Did you basically shim some material between the opening for the speaker and the speaker housing itself? I'd love to see a picture so I can either do this myself or share it with the dealer... the bass rattle is getting on my case (I like my electro and I like my bass turned up about 2/3rds).
markremi (02-08-2021)
Dude, thank you so much for this! I'll try it out here.
I am hoping this is my issue and not something else. The "brap brap brap" with every kick drum hit is starting to annoy me.
Of the many times I have heard the bass rattle, not once was it coming from the speaker. Check closely as this is very deceiving. My experience says it may be something else.
On my car its the protection trim that is slightly loose or not seated properly, if you tap the trim you should hear the same rattle. It seems its loose at the back end and yes I just shimed a suitable sized and colored material and its now dead silent. Hopefully this pic will help (if I can get it to show)
You can quite easy test if its the trim or something else, just put one of your offending bass tracks on and make sure the car goes "brap brap brap" get in the back seat and put your hand on the speaker trim and apply a bit of pressure. If it stops the "brap" then you know its the trim, if not its something else.
I just took a 4 mm tie wrap and pried it in, its around 1mm thick and 4 mm wide.
