Sponsored by:
Sponsored by:
Lowering confirmed via VCDS
Old 09-05-2015, 09:55 PM
  #11
exam23's Avatar
The instruction states "car + menu"
Can someone clarify "car" button? Is it the Start button?
Sorry newbie question..
Originally Posted by redpit107
I lowered mine 10mm. I will see how it looks outside tomorrow as it was storming all day. Now to look into wheel spacers.
Have you put any video files on sd card?
Old 02-22-2016, 12:02 AM
  #12
Intero's Avatar
Arrrgh,
First of all, thanks for sharing your finding!
I have messed around with VCDS now and I can't get the car as low as I want... LR value was 419.6 and the software will not accept a value above 435. This means that I can only lower 15.4mm in the rear and that is about half the way i'd like to go. Ideal for me is probably 25-30mm.
When I try to enter a value above 435 it just gives me the "Request sequence error" message.
Any ideas? Do I need to get links?
Thanks,
Old 02-22-2016, 02:42 AM
  #13
UnseenS8's Avatar
How is the quality of ride, especially on S8? In my opinion suspension is too soft and if lowering could stiffen it, it would be worth considering.
Old 02-22-2016, 06:06 AM
  #14
Intero's Avatar
It's def stiffer after lowering.
Old 02-25-2016, 07:48 PM
  #15
pdt6974's Avatar
My results. Definite improvement.
Old 08-14-2016, 11:32 PM
  #16
UnseenS8's Avatar
My European S8 2015 went down 20mm yesterday. It was 41cm from mid rim to arch, now it's 39cm. I have 20 inch wheels.
So far I didn't notice any change in ride quality but I will test it more. Driving my other car at the moment.
Old 11-07-2016, 08:53 AM
  #17
audisession's Avatar
I have a 2013 S8.
I couldn't get it to work for me.
I am using the latest version of VCDS and after I select LF, RF, LR and RR - I see different heights for each corner. (Shouldn't the LF and RF be the same, and the LR and RR be the same?)
Then I tried to add 3mm, 5mm, 10mm to just the LF corner and I get a "Request Sequence Error" message.
Thoughts?
Old 11-07-2016, 09:08 AM
  #18
MP4.2+6.0's Avatar
Originally Posted by audisession
I have a 2013 S8.
Thoughts?
FWIW, my 2015 S8 that had been untouched with any mods had differing values left to right as well as front to rear. Factory dials it in somehow, presumably in an alignment jig process. They have to deal with the remaining tolerances of manufacturing and assembly in truing it up.
Old 11-08-2016, 02:01 PM
  #19
update: i got it to work - reduced by 10mm...It looks amazing!
Old 01-04-2017, 06:20 PM
  #20
Fez2013's Avatar
Hi All, Would it be possible for someone to help me with the lowering using VCDS? I have the software just need some assistance if someone can do it remotely? I did it on my D3 but the D4 instructions looks more detailed and complex. Any help would be appreciated.
Quick Reply: Lowering confirmed via VCDS
