Replacing rear pads on '12 - what about rotors?
I got the message in my dash today that I need to replace my pads. After a quick inspection, it seems like it's the backs.
I called the dealer for a price: $1100. I said I'd do it myself, and the service manager informed me I'd need a scan tool to set the parking brake to the service position - and told me I should replace the rotors at the same time.
I'd previously purchased the shop manual, which confirms the requirement to position the parking brake (and resulted in me ordering the VAG tool from Ross-Tech). However, the manual instructs you to inspect the rotor for runout thickness.
Has anyone only changed pads on rotors that were within tolerance? If so, what pads - and did you get warped rotors after?
I plan to order the OEM pads from genuineaudiparts.com. Does anyone disagree with this approach? I don't care about the dust as much as I want the brakes to function exactly as they do now.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
On rotors, my rule of thumb is basically every other pad change, you need rotors. It can vary some by specific Audi, driving style and such. Worked well on my D3 tracking for 110K miles I have done on it, and 125K cumulative. If anything, I noticed w/ D3 it "only" went two pad cycles in back, like in the front. Older Audis seemed to wear rears pretty slowly. Air ride with D4 or D3 probably contributes to more effective braking in rear and hence more wear.
You answer it more precisely by checking the rotor thickness to be sure it is above minimum spec. Dealers like to say they want to be sure it will still be at minimum spec AFTER the whole next pad cycle if you press or notice the numbers they give you are above the min. spec, which then may lead to a prediction you will (in the future) need new rotors if they drop below spec. Thus all roads may point to selling more rotors at the dealer...funny how that works. You need to decide, but honestly within reason this is the good ole USA (for most of us here). An extreme stop or set of stops in felony territory is less than 100MPH, and for most of us most of time, 80 give or take. The system is designed and spec'ed for 155. Where that is legal in Germany it is with real world stopping or sudden slowing from 100-125 pretty commonly even if you aren't blasting down the Autobahn or doing some YouTube speed run. Remember high school physics and the square of the velocity--it's not linear as far as energy to scrub. Under spec rotors mean less mass to dissipate heat from the pad friction. Whether rotors more worn or less, the friction component though is still the same assuming same pad spec.
As a guess if, you have 35 or 40K miles, I would bet this is first pad change. If double that, second and rotors are probably due. If you are the first owner, you should know. If second owner, might be in dealer service paperwork. You should mic them anyway when you do brake work to be sure. A heads up on the tool--the simple plastic type calipers won't work because they will just measure the rotor outer wear lip. You need a tool that reaches around that; I use an old fashioned micrometer I got from my dad as a hand me down.
Thanks in advance!
Thanks in advance!
I dont know how you drive, but ive noticed A8s can go a bit longer without rotors than say a A4 or a S5, due to calmer driving How many miles on the car? and do you ever notice any pulsing? Also give em a feel and see if theres a lip.
And i disagree with that approach, i say you go with Audi Parts since thats my site and we sponsor the forum
Thanks for the input, guys!
I have 53k miles on the car. I bought it with 42k as a CPO last December.
Is there enough room to reach a micrometer around without taking the rotor off?
If if has to come off, the shop manual says to replace the bolts that attach the caliper carrier. Do these come in the overhaul kit (3D0698671)?
To be honest, if I'm taking the rotors off to measure, I'd just as soon replace them
The brakes have never pulsed.
The Bentley manual I had for my A6's had diagnostic procedures included. For example, how to troubleshoot EVAP codes - including how to use the scan tool to set various self-tests. I didn't see that in the current manual. Did I miss something, or are they no longer included?
MbeggsRS4, I'm switching my supplier of parts. Thanks for supporting the forum!
By the way, it's been a bunch of years, but that address looks like that of a dealer where I bought my 2004 A6 2.7t CPO.
Riverside Audi ?
