Well that is cute
Well that is cute
Still getting acquainted with my new S8. I went out this evening to run an errand and noticed that the red-line on the tachometer changes as the engine warms up. How about that. Pretty amazing.
I am used to quite a bit more instrumentation in my Porsches. Are there after market options for measuring such things as turbo boost, oil temperature, etc.?
Oil temp might be hidden not entirely sure. I know the S4 has a laptimer where they bury the oil temp. Boost is probably hidden somewhere too. It would take some time playing in VCDS to see what you can find.
Prior to the a couple Porsches I had a Maserati Quattroporte, a wonderful, sexy car but I never liked it more than I did on the day I took delivery. With the Porsches and now the S8 I like the car more after having it for a while than the day I took delivery. Not sure what that means or why, but I kinda like it that way.
With a Ross-Tech cable, you can enable the lap timer function in the DIS. Bringing up this "page" with the little menu button on the left side of the steering wheel next to the scroll wheel will also display the oil temperature and a boost gauge, though the latter is just a small vertical stack of bars with no absolute value, just a relative display between 0 and MAX. In manual mode, this screen will also display a progressive series of horizontal bars that function as a shift light.
This is the one you want: Ross-Tech Store: VCDS License with HEX-USB+CAN Unlimted VIN (All VAG)
There is also a WhyFi version, but it's not ready for prime time in my opinion.
I hear ya.
They failed badly by making it Windoze only, and tried to fix that with what is called HEX-NET.
It's an interesting product, and I was foolish enough to buy two of them.
You are stuck forever using a USB cord to update it, required to tether it to your phone and pray the cloud functionality works, among many other quirks.
They also seem to have very little interest in making it work properly with the D4 model.
You may ask around on the forum(s) to see if there is anyone near you who has VCDS and could assist.
If you'd like I'll look up the factory procedure in erWin.
The only diagnostics assistance I do anymore is for D4 owners
