1993 audi 100s back up lights not working
I have a 1993 audi 100cs automatic. recently replaced the bulbs and checked the fuse and the reverse lights are still not working. any ideas would be appreciated thank you
Question..Do you have auto mirror dip on your car? Is it working? With the button for the passenger side mirror pushed in, then put the car in reverse. Does the mirror glass rotate down (dip)?
This may be an early warning that your transmission control switch is failing. This is a purely mechanical switch buried under the transmission, part of which controls that back-up lights. It is a clamshell design secured with rivets and the may start to rust out. The result is that some contacts inside the switch may not work properly. I do not want to alarm you unnecessarily, but if everything else ckecks out this is a possibility. Bad news, the switch is ~$600 if you can find it. Good news, you can fix the old switch, by cleaning lubricating and replacing the rivets by 2mm X 8mm screws.
I will look up the wiring diagrams to suggest other reasons for the problem, although my recollection is (I did this 7 years ago) that the circuit is pretty simple and although the switch closes the circuit for the auto mirror controller, they are in parallel, so I doubt RustySpokes's hypothesis, but I may be wrong.
Mr. Timewise
Audi allroad
14
12-20-2007 01:11 PM
philip200qt
29
03-03-2006 05:15 AM
Mike Desi
Audi Original "S" Cars
08-18-2003 10:48 PM
