How many Audi 100 onwers are out there?
#72
Good luck
Let us know if you need any info or know-how. Just finishing a pretty substantial mechanical refurbishment on a 92 100CS wagon: Head-, oil-pan- oil-pump-, intake-, exhaust-gaskets, brake lines, timing belt, and taken the opportunity to refresh or refurbish all kinds of seals, shields, brackets, and tubing. Also replaced noisy heater/AC fan. Re-mounting exhaust now. Almost done.
#73
Vacuum hoses
#74
I broke the hard plastic tube for the brake vacuum assist that goes over the left valve cover during disassembly. As far as I can tell that part is impossible to find. So I made a sleeve of softer rubber tubing and secured it over the broken section with rings.
#77
New lifters will take care of it. I rebuilt the heads on the old one I had. I dont have it anymore, but it was a noisy POS, and I took the heads off, new exhaust studs and gaskets, lapped the valves, new stem seals and new lifters. Was very very quiet, and oil consumption went from 1-2 quarts a week to a quart over a 6k miles synthetic oil change.
#78
audu 100 2,8 quattro
Hi! I am trying to get my 1992 2,8 Quattro Automatic on the road again after 2 years in a garage here in Norway. First job is to change the Automatic transmission Starting this week. Tips to awoid difficulties will be great Its a great car that is worth saving.
#79
#80
