Key FOB
Key FOB
Good morning to all board members,
I searched all threads concerning FOB issues tried the different methods and nothing works for me.
I own a 1996 Audi A6 C4 model. I bought it used and I had only one key when I bought it which is a big key with only one button it is a hella HUF 443837220D on the blade on one side HAA and the other side HUF signature... It is really a blade key non flip.
My central locking pump broke and I found a replacement with the exact same replacement part numbers. When I use the key manually the doors open and close and the alarm is switched on or off... But the doors do not lock or close when the single button on the key is pressed. It was working before my pump broke down...
Is there a method of make my key known to the car or has the central locking pump something to do with it? Thanks for the time you will take to answer me because I m turning nuts not finding the answer and make the remote work again
Have a nice day
Best Regards
Philippe
Have a nice day
Best Regards
Philippe
Just to add a few details I tried the method described in the forum put second key start close the door manually with remote key then push the button one beep then...i push the button let it pushed 10 20 seconds nothing happens... Any clue? Thx for your help...
ok..I am assuming you have the radio transmitter key and not the infared type... the procedure must be completed in 30 seconds. You will need 2 car keys and all remotes you want programmed, control unit will handle up to 4.
Turn on ignition with key #1. Insert key #2 in drivers door lock , turn key locking door slowly,hold the key in the lock position ,with your other hand press both buttons on the remote until the car unlocks itself. (I don't know about your Hella key with one button..most here in the USA had two or three buttons)
Re-lock car holding key again press both buttons on remote #2 till the car unlocks itself again. Repeat this procedure for up to 4 remotes. Remember to leave ignition on till you are done entering remotes.
Do not try and work locks with a remote you have entered till you turn the ignition off.
Thanks for your message I have been trying this procédure for à few rimes already but does not work I will dismount totally the remote and see it looks like there is à problem in the remote Anyway thanks you for having take the time to answer
If you can get a Ross-Tech or VagCom check the programming on the control module..here in the USA the module coding default is 12172 or 16140, depending on what radio was installed in the car.
Could be the control module has incorrect coding for your car.
OK good news after dismounting the remote cleaning all parts it finally worked My remote is working again Thx for all the answer Now comes the nastieSt part immo box then the car will be on the road again
GreenA4
06-18-2006 07:23 AM
Oo.et.oO
15
10-11-2005 08:23 AM
marc_in_england
Audi 100 / A6 (C4 Platform)
10-21-2002 05:40 PM
