How many of u have ever checked ur brake hose, if not please
Old 02-04-2009, 05:18 AM
New Member
A6George's Avatar
Default How many of u have ever checked ur brake hose, if not please
<center><img src="http://pictureposter.audiworld.com/138084/broken_brake_hose.jpg"></center><p>My Brake hose failed just after i pulled in from highway for a Burger(lucky it was not on highway)
The pedal was soft and went all the way to the floor . No brake at all!. Luckily this happened when i was about to get back to highway from burger place..
Now i have replaced both the front hose , bleed the brake and its fine...But a word of caution ..Please check your brake hose/line
Old 02-04-2009, 05:30 AM
Audi Logic's Avatar
sabotage? that's a awfully clean cut.
Old 02-04-2009, 07:27 AM
austinado16's Avatar
Default Very common for them to crack and ultimately fail at these locations near the metal fittings.
I see this all the time, on almost all cars. Fortunately, the PO replaced my front hoses with braided stainless steel versions, and the rears with rubber.
Old 02-04-2009, 07:53 AM
DaveInSaltLake's Avatar
esp if they're stressed during axle replacement.
Old 02-04-2009, 09:32 AM
Zwoobah's Avatar
Default keep an eye on those stainless hoses too
they also like to fail near the metal fittings - check every few months. see my pic poster for my old stainless rear hoses.
Old 02-04-2009, 10:14 AM
Wow, those got nicely FUBAR'd. Thanks for the tip.
Old 02-04-2009, 01:02 PM
Just Me's Avatar
Default I even put a how to in the tech section. After about 7-10 years they show signs of danger.
I just did all my liens in a '95 C4, and plan to do my C5 in a couple years.
Get top quality flare nut wrenches. Dont ask how I know.
G
Old 02-04-2009, 09:08 PM
New Member
A6George's Avatar
The actual cut was small,i sliced it later for easy removal
Old 03-19-2009, 08:00 PM
New Member
J-RAD's Avatar
I'll tell you, I just got done replacing my front brake hoses (driver's front broke over the weekend). They are very problematic. The issue is that the hoses are too short - I don't know how they lasted 10K let alone 180K.
Just take the wheel off once and turn the steering wheel from stop to stop. You'll see just how much that brake line is stressed - right at the same point as A6George's.
This was such a concern that I ended up having custom brake hoses made for the front. They are 2 inches longer than the spec replacement hoses.
Definitely inspect those lines!
Old 03-20-2009, 03:36 AM
Greyhound Guy's Avatar
I already did mine. Doing the backs next.
Quick Reply: How many of u have ever checked ur brake hose, if not please
