What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
Old 07-15-2008, 03:27 PM
quattro90S6's Avatar
Default What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
its for our A6, 1996 auto Q. Terminal 30 is that the fuses by the A pillar? I have no idea what any of it really means but we need to get an inspection sticker...stupid MA
Old 07-15-2008, 05:52 PM
Just Me's Avatar
Default Well, hard to guess at all of it, but
B+ refers to the output of the power supply, + rail. Most symetircal power supplies run "B+ and B-". Of course, since cars are single ended, thsi is kinda stupid.
Assume the first number is a code, referencable to the factory service manual. do you have it?
Assume the 2nd denotes WHICH power supply, and that the "power supply" is really a regulator somewhere.
The terminal is probably on that PCB.
All guesses.
Grant
Old 07-15-2008, 06:29 PM
Joey T
Guest
Posts: n/a
Default Common code. Did you clear it and it returned?
It won't set a MIL by itself ( at least not on the B5 cars ) and will not effect readiness codes.
Do you have a VAG-COM? You can force teh monitors. What engine code/model?
Old 07-15-2008, 06:41 PM
Default yes it keeps coming back, goes away for a bit and comes back on...
i do and the P1602 is and Audi code i believe, its the only code preventing us from getting an inspection sticker and its annoying as all hell
Old 07-15-2008, 06:44 PM
Default its a 1996 C4 A6...ill go out and do the code again, and what are the "forced monitors"....
new to VAG, and look at the engine code
Old 07-15-2008, 06:56 PM
Default im in the car now and it's under Mode 03: Emission realated fault codes....
Address 10(Engine): 1 Fault Found:
P1602 - Power Suppy Terminal 30: Voltage too Low
this is after converting it from Audi codes to VAG codes and this is the only code there is
Old 07-15-2008, 08:12 PM
austinado16's Avatar
Default I would start by throwing a dealer/Audi ignition switch at it, and see what happens.
But you don't say if this is an engine code, air bag code, ABS code, transmission code, or what.
Old 07-16-2008, 07:26 AM
ricoblanco's Avatar
Default The Bentley sez:
"J220 - Motronic Engine Control Module (ECM) Supply Voltage"
Ewww....I e-mailed the test procedure from the manual to you FWIW. I think <b>austinado16</b> may be onto something with replacing the ignition switch though. Otherwise, try to locate fuse S103 (I don't know where it is at the moment).
Old 07-16-2008, 07:49 AM
Default CEL...i'll try that it has 167K, would a switch out of a 1994 UrS4 work?
its a parts car that i have here right now<ul><li><a href="https://forums.audiworld.com/a6100/msgs/91572.phtml">https://forums.audiworld.com/a6100/msgs/91572.phtml</a</li></ul>
Old 07-16-2008, 07:50 AM
Default i just looked at it, the email, thanks a TON...
ill start looking at it when i get home, off to NH for some other audi parts...yay.
Quick Reply: What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
