[HELP] 1992 100CS NON Q radiator compatibility
Old 05-20-2015, 11:27 PM
Cks69's Avatar
Default [HELP] 1992 100CS NON Q radiator compatibility
I need to know if a radiator from a 12/96 A6 2.8 Automatic Quattro, will fit my 1992 100CS 2.8 Manual Trans. NON-Quattro.
Are the compatible?
Thanks.
Old 05-31-2015, 10:23 AM
browalke's Avatar
Are the compatible?
Thanks.
I know the early 1992 production year had different rads. Mine is a very early 92, production date of 7/91 and when I had to replace mine I had to get a rad with the extra heater hose size outlet for the oil cooler. I believe the change was made 4/92. I have a 1993 100cs parts car and it does not have the extra water outlet near the bottom. Hope this helps.
Old 08-09-2015, 05:33 PM
Cks69's Avatar
Yep, nailed it. Mine is an early production year.
Would it be possible to get a radiator from a later build and block of the oil coolant fluid?
Any gurus out there know if this would be possible?
Thanks.
divil
07-31-2012 10:55 AM
mattmondo
Audi 100 / A6 (C4 Platform)
01-04-2012 05:51 PM
Daniel917
11-15-2011 08:52 PM
Jack in FL
06-01-2003 08:16 PM
IslandS52
12-08-2002 06:03 PM
Quick Reply: [HELP] 1992 100CS NON Q radiator compatibility
