1990 Audi 200 wagon randomly will not start
Old 10-20-2014, 05:45 AM
  #11
Kneale Brownson's Avatar
No tachometer activity while cranking is a symptom of a bad engine speed sensor. The two sensors (ignition reference and engine speed) are not as exposed to heat on the I5 engines as on the V8s, but they're 25 years old in this case. Certainly worth testing.
Old 10-20-2014, 07:43 AM
  #12
a-talk's Avatar
Also, you should pull codes from the ECU. Even in a no-start condition, codes can be pulled. If there is a hall sender or engine speed sensor issue, it will be logged.
Old 10-22-2014, 06:09 AM
  #13
audiqv8's Avatar
Default Sound like both speed and crank sensor
Sound like both speed and crank sensor are failing. If the speed sensor fail while the engine is running then the engine will stop, if the crank sensor fail then the engine will not start. Both crank and speed sensors are magnetic sensors and as we all remember from high school physics, a magnet loses it magnetic property when heated. Once you stopped the car the heat under the hood, especially from a turbo engine will continue to climb. This will cause either the crank or speed or both sensor to fail. If this was my car I would replace both sensors.
BTW if the crank sensor fail while the engine is running , it will continue to run, but will not restart after the engine is turned off.
Old 10-22-2014, 08:48 AM
  #14
eventoday's Avatar
Thanks for the info.
I will mention this to my mechanic.
He is really terrific with vanagons but I dont know if he knows the quirks of old Audis. Any info I can give him is great.
Old 10-22-2014, 10:29 AM
  #15
eventoday's Avatar
Update: so just talked to my mechanic and he said when it won't start it is not getting fuel. He is not sure but says signs are leading toward fuel distributer. He is going to try and clean it.
Any thoughts?
Old 10-22-2014, 10:45 AM
  #16
audi_marv's Avatar
Fuel pump relay. The underhood heat theory also applies to relays. This fault should come up when you run the codes. If you have the relay type with the fuse connector, when it won't start, put in a fuse and see if the fuel pump runs (you should be able to hear it). Messing with the fuel dizzy may open up another different can of worms...
Old 10-22-2014, 05:18 PM
  #17
yodasfro's Avatar
This^Yikes tell the mechanic not to mess with the fuel distributor.
Old 10-24-2014, 05:26 PM
  #18
eventoday's Avatar
New Update:
Hi Again,
So I got the car back from the mechanic today. Still kind of struggling finding the issue.
He purged the fuel system and changed air and fuel fileter.
Added some other fuel cleaning additives too.
He found out when it wont start if you hold the gas pedal to the ground (which he said keeps throttle body open) it will fire up after about 3-5 seconds.
I found out this is true today when it wouldnt start.
He told me to drive it for a week and see if anything changes.
He also mentioned it is not getting proper amounts fuel when the warm no start is happening.
I dont know what it is called but he said the plate underneath the fuel distributor in not operating correctly. He said he tested the sensor that operates it and it is working.
Am I making sense?
Any thoughts for me?
Old 10-26-2014, 06:18 PM
  #19
audiqv8's Avatar
Originally Posted by eventoday
New Update:
Hi Again,
Am I making sense?
The plate underneath the fuel distributor is raised by engine vacuum, therefore verify the plate is not sticking and also check for vacuum leak(s).
Old 10-27-2014, 05:43 AM
  #20
eventoday's Avatar
Thanks Audiqv8,
I will bring that up to my mechanic too.
One thing I failed to point out .
My secondary cooling pump does not work. I didnt think it really did anything ( i know its there for a purpose) but another member asked me if it was working.
Is that a part I can find easily? expensive?
Quick Reply: 1990 Audi 200 wagon randomly will not start
