audi 5000 won't crank
Old 06-01-2014, 01:32 PM
hertfordnc's Avatar
Default audi 5000 won't crank
Car was running great. I was troubleshooting the AC and when i tried to start it there was nothing. no click.
The dash lights up, everythign comes on with the key but the starter does not try to engage. No click from the solenoid.
Old 06-02-2014, 03:21 PM
Pushbutton_auto's Avatar
Go over everything you removed or altered when t/s the AC.
Make sure you are in neutral or park .... yeah I know
If it was running great, up till you t/s the AC, then it should still be, if however there is a time lapse between running great and trying to start now, then you have battery checks, earth wire checks, starter connection checks, etc
Old 06-02-2014, 05:55 PM
hertfordnc's Avatar
THere is no neutral saety swithc on this car, right? In fact, this car is the reason most cars today have neutral safety switches,
Of ocurse i looked allaround what i touched while messing with hte AC, i serviced it at the fitting by the firewall, i jiggled the wire going into hte compressor.
I assume the problem is related but it would help if someone coule identifiy a particular compontent or wire.
Old 06-02-2014, 10:05 PM
The car will only start if in neutral or park.
Old 08-17-2014, 04:20 PM
x19
x19's Avatar
[QUOTE=Pushbutton_auto;24574412]Go over everything you removed or altered when t/s the AC.
Hi, is your car starting okay now since then? Did you put relay in starting system? I'm so interest about it.
Charley Rogan
07-26-2018 02:19 PM
quaid99
05-31-2017 04:26 PM
cchinny
A4 (B7 Platform) Discussion
09-16-2014 01:43 AM
FSuperDuty
04-13-2007 01:01 PM
The Crapple
Audi Original "S" Cars
16
09-17-2006 10:24 AM
Quick Reply: audi 5000 won't crank
