86' Audi 5000 CS Quattro Turbo High idle
Old 07-11-2014, 01:03 PM
Eli.Spencer's Avatar
Default 86' Audi 5000 CS Quattro Turbo High idle
Hi, I have a manual 1986 Audi 5000 CS Quattro Turbo Wagon, I've had it for about 5 months, it has about 224xxx miles on it. when I start it up, after 10-15 seconds the idle raises up to around 3000 rpms + and stays there. After a bit of research I think it might be a electronic issue, but other than that I haven't the foggiest. Thanks in advance
-Eli
Old 07-18-2014, 05:28 PM
yodasfro's Avatar
A bad ISV (idle stabilizer valve) can cause this. Try remove it and cleaning it with WD-40.
There is also an ISV control unit it's a double wide relay in the relay panel behind the drivers knee bolster. Try giggling it a little or remove and plug it back in.
Old 08-15-2014, 02:42 PM
Thanks a million! I cleaned out the ISV but no luck, ended up finding one for 35$, just installed that and the 5000 is purring like a kitten, and not screeching like a 5 cylinder at 3000 revs.
-Eli
little_e
07-19-2011 12:29 AM
zabu302
09-05-2006 04:51 PM
green a4 sIII
Audi Original "S" Cars
10-16-2004 04:30 PM
nowers
03-07-2004 04:42 AM
audiluver
01-27-2004 04:49 PM
Quick Reply: 86' Audi 5000 CS Quattro Turbo High idle
