V8 engine - hybrid
V8 engine - hybrid
So.... I have decided to go for it. I already have AHC engine from early S8.
My plan is to leave block from ABH and heads and everything on them to mount from AHC. BUT !! Question is what to do with ECU ?? I'm thinking to leave existing original from ABH, just to map it using wideband O2/EGT sensor
http://www.vems.hu/products/round/EN/
Really don't want to f**k around with AHC ECU and automatic transmission ECU from V8Q
Would like to here any opinions regarding this project.
..... and it's verrry good !!! My target is to get rid of high voltage leads and distributors, and after this I will be able to install vacuum for the brakes and get rod of brake bomb.
I shall watch with interest...
I am contemplating fitting a later V8engine into my 1990V8 chassis. Ideally, for now, I'd like it to be as simple a mechanical swap as possible, with the minimum of electronics changes.
So.
ABZ or AHC engine. Can these be run using PT or ABH electronics?
Will an ABZ/AHC accept heads and valve gear from a ABH, so allowing it to run normal distributor ignition.
So.
