Climate control and blower motor staying on
Old 02-10-2016, 08:32 AM
Nvncibl's Avatar
Default Climate control and blower motor staying on
Guys,
My 1994 90Q has recently developed a new issue. When I turn off the car, the climate control stays lit up and the blower motor continues to run. I've been lowering the blower level to "off" to save the battery but I was forced to pull the battery negative last night. I searched and couldn't find the exact same issue. Do I start with the relays? Maybe some corrosion or a bad relay?
Any help with be much appreciated.
Thanks!
Old 02-10-2016, 10:41 AM
Hybrid_Hatch's Avatar
my first thought would actually be to check the ignition switch. if the switch is broken and not fully shutting off the power to things, it could cause this sort of issue.
Old 02-10-2016, 10:42 AM
You could test it by just pulling the plug off the back of the ignition switch and see if it shuts it off.
Old 02-10-2016, 11:00 AM
Nvncibl's Avatar
I will try that asap. Thanks!
btw... I replied to your old PM. Sorry it was so late.
Old 02-11-2016, 03:31 PM
bradwilcox's Avatar
And it might be more convenient for you (and easier on the car) if you pull a relay or fuse instead of the battery?
Old 02-12-2016, 06:36 AM
Nvncibl's Avatar
Good point!
Old 02-14-2016, 06:01 AM
Jiggie's Avatar
Originally Posted by Nvncibl
Good point!
I was just having a simliar issue with my 88 90q.mine only worked when the car was off, once I turned the car on it stopped working. I had to put a new hvac control unit in because there was a short in the unit.
Old 02-22-2016, 01:44 PM
Nvncibl's Avatar
Thanks Hybrid. After pulling the plug from the back of the ignition switch, the climate control unit turned off. Good tip! I'll order a new switch and see if that fixes it. Fingers crossed.
Old 02-22-2016, 02:28 PM
Glad it worked out, honestly the switches are pretty cheap, and very easy to replace.
the_kid_hartford
16
03-14-2016 05:03 PM
Skewoooot
02-11-2016 11:24 AM
freeryan
Audi allroad
02-08-2016 04:12 AM
Rusa
02-07-2016 07:54 PM
mrho888
Q7 MKII Discussion
02-05-2016 08:40 PM
Quick Reply: Climate control and blower motor staying on
