need advice guys :(((
Old 02-08-2016, 09:54 AM
mar5den's Avatar
Default need advice guys :(((
First I would like to say hello to everyone I have an audi 80 1985 on a c reg auto 1.8 and the there is strange noices coming feom the gear box it only make the noice whwn im driving it....is it on its way out???
Old 02-08-2016, 10:13 AM
mar5den's Avatar
Also one of the spark plugs has not veen put in right and has damged the threads in the engine it runs fine but can it be repaired
Old 02-08-2016, 04:08 PM
Rusty Spokes's Avatar
Automatic or manual? I think you indicated an automatic. If it is an automatic..check the ATF level. If that is Okay..when was the last time the transmission was serviced? Check the gear oil level in the differential too..make sure the gear oil is up where it is supposed to be, that is leaking out the gear oil fill hole when you remove the fill plug..on level ground, engine off. A low amount of gear oil will make the differential sing..not good.
Old 02-08-2016, 07:10 PM
CRAZY_RUSSIAN's Avatar
also, on the gear oil, make sure you can remove the filler plug before you remove the drain plug
Old 02-10-2016, 11:59 AM
mar5den's Avatar
I have checked the oil level abd its just over the maximum the liquid is a cherry red colour does that meabs that the problem is internally
Old 02-11-2016, 04:38 AM
mar5den's Avatar
It only makes the noice in 3rd gear any help would be greatful its a whining noice
Old 02-11-2016, 07:16 AM
There are two checks. One is the ATF level with the dip-stick. The process to check the ATF level is transmission warmed up, engine running at idle with transmission in PARK (hand-brake on)..the level on the dip-stick should be between the two marks.
To check the gear oil in the differential..the car must be elevated and level. Engine OFF..(and I am going by memory here..so I could be wrong about the wrench size) There should be a 17mm allen plug or 17mm head fill plug on the side of the diff.
Remove the fill plug and some gear oil should dribble out...it may be low. There should be a drain plug the same as the fill plug. Once the fill plug is out..you should drain the gear oil and then refill with some quality 80w90. Fill the gear oil till it is running out the fill hole..that sets the level..and reinstall the fill plug.
The gear oil may be low and decades old.
Sorry I could not find a picture on a DIY for the gear oil.
Amit128
Q7 MKII Discussion
184
04-01-2016 02:20 PM
DavidA
02-07-2016 06:09 AM
Jcampbell3
Q5/SQ5 MKI (8R) Discussion
20
01-24-2016 02:08 PM
Tuco Truu
Auto Detailing Discussion
01-13-2016 09:04 AM
Phanes97
01-10-2016 10:36 PM
Quick Reply: need advice guys :(((
