Need help: '91 CQ pwer windows update
The problem is the 3 power window switches get 9V when the car is locked and drain the battery.
The windows ONLY work (get 12V) when the fuel pump is priming and engine is running. All other times the windows get 9V.
For example, if the ignition is on and engine is off the power windows only get 9V and do not work. When the ignition is turned on without starting the engine the volts go from 9V to 12V only when the fuel is priming and then go back down to 9V.
I've replaced the power window relay, thermofuse and an ignition switch without any change in this behavior.
I've looked at the wiring diagram and the thermofuse always gets 12V from the battery. But, when I unplug the wires from the ignition switch the power windows drop to 0V.
Any thoughts?
Any thoughts?
Check the ignition switch..if it is old or original..change it. I am sure the part number is 4A0905849B..double check. Audi had several versions of the switch because they caused so many problems. Use an OEM switch if you need one..the aftermarket switches are not very good.
gateway
12-04-2016 04:01 PM
gateway
07-18-2016 11:13 AM
JoeCaymanBWI
11
04-30-2008 10:41 AM
