'96 Cab window adjustment
I just successfully replaced the driver's front window regulator on my 96 cab. It runs full up and down, but in the full up position, the window is misaligned to the inside. How do I adjust the window to track more to the outside? Did some forum searching, and came up short.
http://autopartmaster.com/imgbank/ca...&unit=60B02010
#10 on this picture, but it came with like 4 different thickness and it was installed under all 4 big bolts
The Bentley has a detailed procedure for adjusting the window regulator frame. Varnia is right about those shims too. You may have lost yours when you removed the window regulator. They look like fender washers and fit between the window regulator and the door. The door panel must come off and the window regulator adjusted to fit squarely and not too high or low. Then the fender washers are fitted to move the window in or out to ride correctly in the channels in the roof. You can try fender washers from NAPA if the Audi washers are hard too get.
This is what the Audi shims look like:
But its not that difficult to find out.
Scott F Rendall
04-30-2016 05:01 PM
skidmark
Audi allroad
17
06-20-2005 05:48 AM
beo
11-03-2004 12:25 PM
