engine still not running right... any ideas?
Old 09-18-2009, 02:08 PM
mikekisss's Avatar
Default engine still not running right... any ideas?
i have a 1988 audi 80 4cyl. the car just dosent idle right. It revs up to 1600rpm and then drops down 1200 then picks back up going in cycles. I checked all the vacuum lines, replaced the intake boot, put on a new head valve gasket, new spark plugs, new oxygen sensor, cleaned the isv and throttle body. Yesterday, I accidentaly left the plug to the fuel pressure regulator unpluged and when i turned the car on it had a steady idle but when i plugged it back in, it would start reving like it did before. Any thoughts or suggestions would be very appreciated.
Old 09-20-2009, 07:14 PM
Harowing's Avatar
check all the wires to fuel controls, might also check your fuel lines sounds like your shorting on gas a little bit intermitantly, oh, might also check the carbon canister valve, if that's bugging out it could be bouncing between rich and lean too, though I doubt that's the problem
Togglehead
10-09-2006 01:44 PM
treehunter
07-12-2005 02:36 PM
Z Type
Audi 100 / A6 (C4 Platform)
10-11-2004 07:06 AM
Mike1989TQ
05-02-2003 11:50 PM
djtalon
03-23-2003 08:57 AM
Quick Reply: engine still not running right... any ideas?
