Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
A3 flashed! APR Stage 1 installed
Old 11-19-2014, 08:25 PM
  #11
arU4ic's Avatar
aj6 probably knows this too, but the S3 has a higher performance turbo, and significantly beefier engine upgrades, I looked heavily into this before deciding between an A3 and S3 (I've tuned at least 3 of my audis and 1 vw).
Evolvd, but there is simply no way that more turbo pressure and higher torque and horsepower ratings (31% more) will have no wear and tear implications on a factory spec motor and drivetrain and even brakes. ALL of my APR'd cars had wear issues, I wasn't a psycho when driving either.
If you don't plan on keeping your tuned car for long, you'll probably be fine, but don't expect a long life… I don't even expect a 10 year span on my S3… I think it's pushed a little too hard for a little 2.0 and a factory A3 will EASILY outlive it, even one driven 'hard'.
My 2 cents.
Old 11-20-2014, 02:58 PM
  #12
Evolvd's Avatar
More turbo pressure? Unless they increased the boost on the stock turbo there is no more pressure than before, regardless of how more efficient the air/fuel mixture is. Boost response may increase but that just means your turbo is making that boost pressure slightly faster than before. And you're forgetting one key piece which I already mentioned...wear and tear is based on your right foot, not the ECU mapping (when properly tuned).
As for 2.0 liter motors, there are over a decades worth of Diamond Star motors (Eclipse, Talon, Evolution) that have been tuned and are still going strong. (minus the 6-bolt mistakes leading to crank walk...but that's a build issue)
Enough of the scare tactics...a properly tuned motor is in fact more reliable than factory and I will swear to it. Most of us don't drive everywhere with the go pedal to the floor. Once you start adding or replacing mechanical parts, that's when you increase the possibility of a failure.
Old 11-20-2014, 03:03 PM
  #13
Evolvd's Avatar
Originally Posted by YuiS3
How does this tuning work? Do you have to download stock tune and send them and upload the tuned file? or you replace your stock ECM with theirs? If so, do you get to keep your stock ECM?
They connect a computer to your car and upload the new program. So basically you're just saving a file to your ECU that is different than the one it had from the factory. A good tuner will save your stock tune and give it to you to hold onto in case you ever need/want to go back.
Old 11-21-2014, 10:04 AM
  #14
Fixeroh's Avatar
Have been reading this thread with interest. Thinking of getting my S3 flashed at some point as well. Someone else posted a few weeks ago about REVO getting an additional 75 HP and 75 lb/ft over the S3 base numbers with a simple flash. Authorized dealer/tech would do the flash but the owner could get an module that plugs into the OBD port to switch back to stock numbers. Module would also have 3 performance modes for varying octane ratings of fuel. REVO is has been working with the 2.0 TFSI in Europe as well as the US and seems to have considerable knowledge and experience. Thought I would go through the winter months stock and in the spring/summer try the flash. Still want to read more however.
Old 11-21-2014, 04:54 PM
  #15
YuiS3's Avatar
So is it like hand held tuner, laptop with software and cable or do I have to go to the shop??
Old 11-21-2014, 06:16 PM
  #16
aj6
aj6's Avatar
You have to go to an authorized dealer, they take care of it from there.
Old 11-21-2014, 08:11 PM
  #17
Evolvd's Avatar
It's usually a proprietary software program however eventually they become open-source and anyone can download it and tinker with the ECU maps. That's how it worked out for DSM cars at least....
Old 11-22-2014, 11:42 AM
  #18
arU4ic's Avatar
Well, yes, point made on the right foot I completely agree, but who would do all these go-fast upgrades without enjoy them with their right foot?
Faster turbine speed=higher pressure, higher rate oil viscosity breakdown and more bearing wear. I'm not saying these are catastrophic wear issues, I'm merely stating that there is no way this leads to BETTER reliability. Just sayin'
If these were normally aspirated engines, I might agree.
(BTW, I do enjoy tech discussions, thanks for indulging Evolvd, even if I'm dead wrong, it's a fair and important discussion to have publicly IMHO.) Cheers.
Old 11-22-2014, 11:49 AM
  #19
arU4ic's Avatar
I think APR and other underestimate the value of more moderate or variable performance increases, I would flash my S3 if I could get 10-20 more HP/ Torque but pushing it 75, only IMHO, pushes the HP too far passed the design specs for turbo, engine and (maybe) the tranny. (Although, I am curious to know if the RS3 has a beefier tranny).
Old 11-22-2014, 12:04 PM
  #20
aj6
aj6's Avatar
From everything I gathered prior to the flash, APR has a reputation for relatively conservative programming, particularly with Stage 1 tunes. It's an anomaly among their tunes that the performance increase on the A3/S3 is so dramatic. If you look at other tunes they have available you'll see what I mean.
Assuming they didn't suddenly abandon their philosophy just for one platform, it demonstrates to me that the gains they made (crank numbers, remember) are just particularly good in this one instance, while not excessively pushing the motor beyond what it can reliably produce. Combined with this is the school of thought that Audi made the 2015 A3 intentionally de-tuned to some extent in order to balance the lineup with the S3.
I'm pretty fair in my judgements about purchases and can admit when I've made a mistake, but after a few days now running this software the car performs so much better all around that I don't think I'll be going back. The raw power is there when you want it, for sure, but there's an experience-defining improvement in the way the car moves, shifts, and accelerates during normal and easy operation that truly makes me satisfied with this upgrade. It's something that can be appreciated every mile, not just the fast ones.
Quick Reply: A3 flashed! APR Stage 1 installed
