2010 A3 multiple Bulb errors on startup
Hey everyone, new forum and Audi owner.
Over the last month I've had random bulb warnings but they've always seemed to go away on their own. With in the last two days however, it seems almost as if the entire passenger front lighting set up goes out. Headlights, highbeams, turn signal, fog light, rear turn signal, back up light, brake light. If you turn the ignition off and turn it back on you'll get different codes all the bulbs check out and are in working order. Is there some type of lighting module that I can replace?
Check out the video, Thanks for any help!
Sounds like you have a loose ground wire some where in the Can Bus system. Or a short in a wire. Diagnostics like this can take a lot of time and money..I would take it in and have it checked out.
1 Mean TT
03-18-2005 11:06 AM
TTinCup
9
01-05-2005 09:36 AM
BriCK
07-09-2004 05:47 AM
black225TT
05-21-2003 06:54 AM
sjpicard007
01-08-2002 02:40 PM
