AMI/iPhone 6s Popping and Crackling in Audio, Open Mic Circuit Fault
So, this is interesting...
I have recently been hearing popping and crackling on my Nav+B&O system. During a road trip today to test out some VCDS changes (dynamic steering is like a whole new car!!!), I decided to troubleshoot this a bit.
Here is what I found:
-Only seems to be happening using AMI cabled connection to iPhone; other sources ruled out
-Didn't occur when connecting to iPhone via Bluetooth; iPhone ruled out
-Seemed to be happening only with sunroof and/or windows open; this one had me puzzled!
-Was also particularly windy today
When I was about 10 minutes from home on my way back, I remembered seeing a fault last night in VCDS about a microphone. I decided to blow a little bit into the microphone near the map lights, and what do you know? Tons of static coming through the speakers!
Here is the fault from VCDS:
1564 - Microphone 1
B129B 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 237
Mileage: 24767 km
Date: 2016.04.23
Time: 11:14:45
I can only assume this is the problem. Has anyone experienced this? This problem has been going on for a bit, and haven't connected the VCDS to this A3 until last night.
Was starting to go crazy trying to figure out why windows/sunroof open could be causing this!
Thanks!
1564 - Microphone 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 237
Mileage: 24767 km
Date: 2016.04.23
Time: 11:14:45
Thanks!
So, the dealership service department was able to duplicate this issue with both another iPhone, in addition to testing in several new vehicles with nav-MMI.
I'm curious if anyone else can duplicate this issue: connect iPhone (6s in this case) to MMI via AMI cable, select a song to play in iTunes, while music is playing, blow into the vehicle's microphone, located near the map/dome lights/sunroof controls. Do you hear static through the speakers?
Tenacious auDi
NY / NJ / CT Discussion
12-30-2008 10:53 AM
TwentyValveB5+S4
05-15-2005 08:06 AM
