How do I turn the Mirror upside down ?
Hello guys,
My Audi A3 S-Line (3-door) 8V , year 2016, has the inside mirror upside down. This has affected also the A4.
What's the easiest way to, I guess disassemble the back, and turn it upside down like it should be.
The reason the "wider" part of the mirror usually points down, is a logic one, and it serves to see the bikers coming from behind who are about to disappear in the blind spot.
The way the mirrror is now, looking for the bikers only yields the black of the inside roof of the car.
Some "designer" obviously has never ever driven a car, and that's why they put it upside down I gather.
Any ideas ?
cheers
Any ideas ?
cheers
Well, this is what a normal car internal mirror should look like. You can see that the bottom side of the mirror is LONGER. This has a specific reason, and it helps you to spot vehicles coming from the corners of the rear view window.
However, in my Audi A3 8V (which is now in the garage 2 block away, that's why I attached some other image, I believe belongs to an A1), the longer side of the mirror is on top. this is absolutely WRONG. Question is, is there an easy way to turn it upside down ? rotating it won't work, as the angle does not fit.
I am basically asking if anyone here knows how to "snap the thing out" without breaking it. The back of the mirror is plastic, and looks like a structure, so there must be a way to snap it open somehow.
My mirror has the auto-dimming feature, so I have to be careful the cables don't snap I guess.
Maybe the dudes at CarGlass here in Berlin may know, I will stop by tomorrow and see if they can help, problem is that the car is too new, they may not know it yet.
It may be YOUR opinion that this is not correct because you desire something different. That does not make the design WRONG. Given the engineering resources at Audi's disposal I doubt very much that it is actually wrong.
In my wife's A3, we have absolutely no issues with the mirror and seeing around the car. Maybe you need to re-think how all 3 of your mirrors are adjusted???
Google Images: internal rear view mirror
and tell me how many you see are like the new Audi (i.e. upside down)
For Pete's sake, look at my diagram, if you can't see something wrong with that, then you haven't looked long enough.
