Painting Calipers Red?
Should I do it myself with a kit or do you think there will be an advantage by finding a paint shop to do it where they will apply a clear coat or use a special/professional paint?
Do it yourself. Be sure to buy high temperature caliper paint. Otherwise, the paint will brun off/fade.
For me, painting standard calipers a bright red color is something that people with riced-out coffee-can exhaust Honda Civic owners do. But, if it's something you like, go for it.
drober30; very easy to do yourself. Company called G2 makes a nice kit with a hardener added for the paint to make it last. Have to have the car jacked up with access to all 4 calipers at the same time. Calipers have to be super clean first as well. G2 kit comes with brake cleaning spray but recommend you get another can from AutoZone, etc. I used to do this on my '06 Civic Si. Added to the car I thought. Paint lasted quite well BUT you will still get scrapes and chips over a period of time. The paint has to be used all at once because of the hardener. I repainted mine every 2 years or so in the spring when I switched my winter wheels/tires for the summers. Kit is about $35.
Having said that, I definitely will not be doing that with my S3. The black calipers look great to me with the 19 inch wheels. My car is black and although I'm not blacking out any chrome trim, I like the subdued look. I see some S3s come with red calipers straight from the factory. That option was not made available to me. I'm good with it. If you choose to paint yours, the G2 kit is available from Tire Rack as well as other sources. Other colors besides red of course.
Thanks for the info!
I would only consider painting my calipers red because the S3 does come from the factory with red calipers. I know here in the US only the 2015 Daytona Launch Edition had them but with the 2016s you can tick that option.
Fixeroh, I think my car is a little monotone (its also black). I have had lots of black cars but with as dark as the 19's are, I think the red would add a little pop.
Plus most of the front caliper remains black with the S3 logo, only the outer portion is red.
SaifSiddiqui
06-03-2006 01:32 PM
Juggernaut
07-20-2001 05:02 AM
parkerpt
06-05-1999 02:26 PM
