TT (8S) Steering Wheel Retrofit
#12
#14
S3
Hello i have installed this steering wheel too but all the button couldn't work..
i already modification to the wiring connector that i still need the code to done for it.
Could u might give me a code for it..if possible.
thank u so much
thank u so much
#15
I believe your wiring is not correctly done. I got the coding done by a shop that specialise in retrofitting so I do not know what are the exact codings. But even without coding, all the buttons on the right hand side (with the exception of the telephone button) should work right away. At least this is what I had experienced.
#16
Hey rs200z, are you Hong Kong based? I have the FL 8V S3 steering wheel on the way and I will have the exact same problem as you. As far as I know, there's a shop that has an adapter available to make the drop down menu button work, but it would involves wiring cutting.. Still unsure if I should just leave the button and go with the cutting wire route..
PM me if you want the shop info...
#17
Hello Guys,
Do you know if this steering wheel fits the "Facelift" 8V S3 with VC as in fully plug and play?
Also do you find this steering wheel sits closer to you? like if it has more offset?
Thanks!
JC
Thanks!
JC
#18
But TBH, it sits about the same, you won't feel much difference at all other than the look...
#19
Getting the other buttons to do something isn't easy unless your really into can bus hacking. Here is a video I did of an R8 wheel in an A7. The exhaust button is controlling an external sound-booster module and the race button I have controlling the rear spoiler for now (which isn't on the can-bus). I used the left and right buttons on the left side for comfort turn signals.
Of course I have the menu button working
Just shows what can be done if you work at it long enough.
Audi R8 Wheel Retrofit
#20
